  What is this? Can cause problems? W/Pictures
What is this? Can cause problems? W/Pictures by alejandrissimo
Started on: 06-08-2014 09:50 PM
Replies: 14 (354 views)
Last post by: theogre on 06-09-2014 10:42 AM
alejandrissimo
Report this Post06-08-2014 09:50 PM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, me again here hehe.
So, today my 2m4 won't start, there is crank, there is fuel pressure, there is ecm (no codes) so I start to checking all connectors on the engine harness and I find there is a broken wire somewhere near the ignition coil.
Sadly seems the wire is not fixable since is broken on the end of the component.
Check the image.
Please if you know what is this and if this can cause the fiero don't start let me know.
Thanks in advance.
fierogtx
Report this Post06-08-2014 09:55 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
dont know about the 4 cyl but there seem to be the tach filter
Csjag
Report this Post06-08-2014 10:01 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes that's the tach filter.
johnguzman1212
Report this Post06-08-2014 10:03 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
hold up I have a 87 2.5 am I suppose to have a tach filter cause my led tachs don't work right and Its new. theres nothing like that in my car
alejandrissimo
Report this Post06-08-2014 10:10 PM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
According to Google it seems it's the tach filter. Now, can this cause the fiero crank but don't start?
dobey
Total ratings: 371
Report this Post06-08-2014 10:13 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever it's supposed to have, exposed copper wire being pulled out of the tach filter due to stress, isn't one of the things it's supposed to have.
alejandrissimo
Report this Post06-08-2014 10:21 PM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Btw the wire is not just exposed, it's totally cropped.
I read this filter only controls the tachometer? So can this cause the start problem?
johnguzman1212
Report this Post06-08-2014 11:14 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
no, what I mean is I don't have a tach filter. theres nothing like that in my car. I was looking for it cause the manual said it had one. I have 2 led tachs my cheap one works fine but my big one don't work right and its setup right. do I need that filter? btw when I bought the car the speedometer and tach didn't work.
trotterlg
Report this Post06-08-2014 11:38 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The wire only makes the tach read smoothly, if you think it is making the car not run then just cut the wire off and see if it starts. Larry
alejandrissimo
Report this Post06-09-2014 12:17 AM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I jump the filter and the tach is back to work.
Also I detach and attach the distributor wires and now the car is running.
The weird part is sometimes when I stop at Red light the engine turns off by itself (hehehe like the Porsche Panamera) do you think this means my spark plugs or wires are defective? I think last time I change spark plugs was about a year ago.
dobey
Total ratings: 371
Report this Post06-09-2014 09:14 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the 87-88 2.5 have it, as they are DIS, IIRC.
dobey
Total ratings: 371
Report this Post06-09-2014 09:16 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
It could be any number of things, including the plug wires, EGR, coil, plugs, etc…
Report this Post06-09-2014 09:45 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is why you pull tach filter when have problem w/ HEI.
See my Cave, HE Ignition
If stil has problems shutting down:
plug and wire, likely not
coil and electronic in distributor, likely
bad wires or iffy C500 in engine bay, likely
even iffy ECM or wire/sockets to it, likely
Bad tach filter can kill coil and/or module.
shorted filter can keep power flowing thru the coil and coil can fry.
as for 87 engine can't see filter... doesn't use it.
Try start reading in my Cave, Duke Quick Ref and DIS Ignition
alejandrissimo
Report this Post06-09-2014 10:23 AM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I need to put a new filter then?
Thanks.
[This message has been edited by alejandrissimo (edited 06-09-2014).]
Report this Post06-09-2014 10:42 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remove filter.
Fix whatever else and drive to make sure.
install new filter.
