  Carbruated air conditioning problems
Carbruated air conditioning problems by triker
Started on: 06-08-2014 08:14 PM
Replies: 2 (112 views)
Last post by: RWDPLZ on 06-08-2014 09:31 PM
triker
Report this Post06-08-2014 08:14 PM Click Here to See the Profile for trikerSend a Private Message to trikerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I carbruated (carbureted?) my 3.4 and now my air conditioning compressor won't engage. I see it is controlled by the ecm under certain conditions but, I don't know what I need to do to bypass the ecm. Thanks, in advance.
triker
Report this Post06-08-2014 08:20 PM Click Here to See the Profile for trikerSend a Private Message to trikerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I should add, it's an 87 GT auto. Everything works great with the Holley 350 cfm 4 barrel except no air. I still haven't got my cruise hooked up but, that's only a matter of making a mounting bracket for the cruise throttle cable.
RWDPLZ
Total ratings: 305
Report this Post06-08-2014 09:31 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hook up the dark blue wire on the compressor control relay to ground. The only problem with doing it this way, is the AC will not shut off if the car is at wide open throttle, since that was computer controlled.
