  TLG switchback led
TLG switchback led by taps
Started on: 06-07-2014 09:24 PM
Replies: 2 (199 views)
Last post by: taps on 06-07-2014 11:47 PM
taps
Report this Post06-07-2014 09:24 PM Click Here to See the Profile for tapsSend a Private Message to tapsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I just have a quick question,
i purchased these switchback leds
and they sent me some resistors, in his video he shows that you just plug and install the new parts,
do I need to install the resistors or no?
IMSA GT
Total ratings: 250
Report this Post06-07-2014 11:15 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure you have seen cars in your area where the turn signals flash VERY quickly.....almost too fast. Some people like that and others do not. That is because the person changed to LED bulbs and did not consider the load loss on the circuit. Factory flasher units work off of the load of the standard light bulbs to create the flash speed. LED lights have very little load so the stock flasher unit flashes the LED's very quickly.
If you use the stock Fiero flasher under the dash, the resistors will need to be used to slow down the turn signal flash rate. If you use the new style that Chris offers, you do not need the resistors.
[This message has been edited by IMSA GT (edited 06-07-2014).]
taps
Report this Post06-07-2014 11:47 PM Click Here to See the Profile for tapsSend a Private Message to tapsEdit/Delete MessageReply w/QuoteDirect Link to This Post
perfect thank you!
