  4.9 with Stickpony Chip Check Engine ON but no code
4.9 with Stickpony Chip Check Engine ON but no code by falcon_ca
Started on: 06-07-2014 06:29 PM
Replies: 5 (268 views)
Last post by: Mickey_Moose on 06-10-2014 05:52 PM
falcon_ca
Report this Post06-07-2014 06:29 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Title said it all
Where should I look other than the wires ?
Neils88
Total ratings: 56
Report this Post06-07-2014 09:42 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd start by talking to Stickpony...
falcon_ca
Report this Post06-07-2014 10:01 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is he still around ?
Total ratings: 290
Report this Post06-07-2014 10:28 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have to use a scanner to read codes on the 2240 ECM, or if you are running the BCM and have the heater controls hooked up they display there. You can not use the paperclip to read the codes.
If you are interested I do sell scanner cables that work with the 4.9 ECM.
http://reddevilriver.com/aldl.html
falcon_ca
Report this Post06-08-2014 08:16 AM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
phonedawgz.
I use Tuner Pro to read the code. It used to work find but this time no highlited code .
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 | Work done 11-12 | Work done 12-13 |Work done 13-14 | 4.9 Swap |Parts for sale
Mickey_Moose
Total ratings: 145
Report this Post06-10-2014 05:52 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
was it working for some time and just develop this problem, or did it happen right after you installed the chip? Maybe an issue with the check engine light wiring?
