  ac compressor
ac compressor by johnguzman1212
Started on: 06-03-2014 10:48 PM
Replies: 7 (372 views)
Last post by: johnguzman1212 on 06-05-2014 11:56 PM
johnguzman1212
Report this Post06-03-2014 10:48 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
I own a 87 fiero 2.5 duke all stockengine, if I remove the engine for an overhaul can I keep the ac refrigenate or will I have to disconnect the hoses and do the ac over?
84fiero123
Total ratings: 325
Report this Post06-03-2014 11:08 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sure just take the ac compressor off the engine and leave it in the engine compartment while removing the engine.
Steve
TopNotch
Total ratings: 60
Report this Post06-04-2014 07:59 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I dropped the cradle on my 88 duke recently (to replace the throw-out bearing), I just disconnected the AC hoses. Then when I got it back together, I pulled a vacuum on the system and re-charged it. It works fine. However, if you haven't previously converted to R134a, and want to keep R12, it would be better to remove the compressor and leave it with the car.
Lou6t4gto
Report this Post06-04-2014 03:42 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the hoses are long enough to get the compressor off, with the hoses still attached on a 2.5 . the compressor (On mine), is mounted onto 2" long studs that the compressor must slide forward on to come off.
sardonyx247
Total ratings: 219
Report this Post06-05-2014 03:27 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well yours is special,... err I mean different, no studs normaly.
Yes just unbolt the compressor and hang in as not to stress the lines(IE tie a string/wire to it and tie it off to the deck lid hindge bolt, so it hangs at normal height), then pull the engine, as you pull it keep an on the compressor, just to make sure it doesn't snag.
I have done it many, many times.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Report this Post06-05-2014 07:41 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou, the engine didn't come with studs as a part of the block, so they can be removed. If there's enough threads exposed above he standard nuts, thread another nut onto the end of the stud. Hold the original and tighten down the extra nut. Then loosen the original nut. The jam nut will allow you to turn the stud without removing the nuts. The stud should come out so that you can leave the compressor hanging in the car.
Lou6t4gto
Report this Post06-05-2014 01:01 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
oops, I was wwwrong. the 2.5 compressor I used (with swapped clutch and pulley) was threaded, so it used Bolts, I drilled out the threads to put on my 3800SC that uses Studs. sorry bout that. too many projects
johnguzman1212
Report this Post06-05-2014 11:56 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
thank you very much . in my fiero it has a murcielago body with extended ac hoses the ac worked for a day cause I got ripped off , so im taking it to another shop to refill with refriganent . they broke my hoses . I bought new ones and now my engine smokes a little due to bad piston rings im unable to fine a good mechanic to do a ring job but I want to drive the car but its hot in texas I need ac
