  injector fuse number 2
injector fuse number 2 by Robert 2
Started on: 06-02-2014 01:29 PM
Replies: 18 (391 views)
Last post by: Robert 2 on 07-04-2014 08:44 PM
Robert 2
Report this Post06-02-2014 01:29 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi i blow all the time the injector bank number 2 fuse .
Just this morning i blew 5 fuses whitin 10KM or 6 miles . What could cause that ????
Thanks in advance
Robert
[This message has been edited by Robert 2 (edited 06-03-2014).]
Total ratings: 290
Report this Post06-02-2014 01:46 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unplug your EGR control valve and see if it stops blowing.
Robert 2
Report this Post06-02-2014 03:25 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll try that .
But what is the relation between the injectors and the EGR valve connection ?
And if it's the problem what to do ?
Thanks .
Robert 2
Report this Post06-02-2014 04:42 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robert 2
Member since Jan 2006
Tried it did around 1/2 mile fuse blew again .???? ( EGR ) connection .
And what bank the number 2 injector fuse is related to , trunk side or firewall side ?1 3 5 or 2 4 6
[This message has been edited by Robert 2 (edited 06-02-2014).]
Robert 2
Report this Post06-02-2014 06:17 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robert 2
Total ratings: 290
Report this Post06-02-2014 06:17 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well then it is not the EGR control valve.
If the harness was ever removed it could have been re-installed either way. There is a six pin connector near the egr control valve where the engine harness plugs onto the body harness. Which pin, the pink or the pink/white doesn't have power with the fuse blown?
No damage to the harness?
Start the engine and put your hand near the exhaust manifold. It will be clear rather quickly which bank is firing.
Francis T
Total ratings: 119
Report this Post06-02-2014 10:51 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both banks are Y feed to the exhaust, thus its not true dual system, no way to tell with your hand without oping the Y. Simply remove a plug wire if it don;t make it worse that one or bank is firing.
Total ratings: 290
Report this Post06-02-2014 11:05 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boy I would sure think the exhaust manifold that had hot exhaust gasses flowing through it would heat up a lot quicker than the one that just had cold air flowing through it, but then I have not tried it. I would do it at start up since then the one manifold won't be so hot, and neither will the entire engine bay.
Robert 2
Report this Post06-03-2014 05:58 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
did the test by removing the fuse no 2 ( fuse was good so i had to remove to simulate a blow'n fuse )
Results pink/white 13.64 volts
pink vary from 13.20 to 13.50 volts
Did the same for fuse no 1
results pink/white 13.40 volts
pink 13.95 voltsIs . Is there a way to find where the short is occuring ?
Thanks That is with the engine running .
Robert 2
Report this Post06-03-2014 10:41 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robert 2
bump
[This message has been edited by Robert 2 (edited 06-04-2014).]
Robert 2
Report this Post06-04-2014 08:13 AM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Total ratings: 290
Report this Post06-04-2014 10:08 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
How does the injector power wire still have power on it with the fuse removed?
Robert 2
Report this Post06-04-2014 12:30 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't know !
But this is what my ohmeter is giving me .
Does not give me the same with the engine and the key in the ignition on the off position .
But il' check again to be sure .I checked yesterday maybe ten time before writing the message .
Robert 2
Report this Post06-04-2014 07:12 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robert 2
i played with the ohmmeter again with engine off ignition on fuse " 2off"
pink/white 11.82 V
pink 11.82 V
ignition "
Total ratings: 290
Report this Post06-04-2014 07:18 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the engine run like crap when the Injector #2 fuse is blown?
Robert 2
Report this Post06-04-2014 07:31 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
pink/white 11.82 V
pink 11.82 V
ignition "off" fuse "off"
p/w 0.00
p 0.00
fuse 2 off engine running
p/w 14.03V
p 13.46
fuse in
p/w 14.20V
p 14.20V
I know this is a nonsense don't know what to tell .
Found out the fuse no 2 is the one that feed the trunk side bank or 1-3-5
By testing with the exhaust trick the trunk side i could touch but the firewall one was too hot almost immediatly after starting the engine .
Also at the end i wiggled the injectors harness and the fuse 2 blowed right on .
After i wiggled all the wires in the engine compartment after replacing the fuse and it never blew again .
Went for a ride half an hour and everything's fine
Thanks
Robert 2
Report this Post06-05-2014 12:20 AM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
's
yes sir run on 3 cylinders . But before the fuse blow it's running good and pull well .
not much power but it's running giving a chance to get the car on side off the road.
[This message has been edited by Robert 2 (edited 06-05-2014).]
Robert 2
Report this Post06-05-2014 11:14 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Robert 2
Bump
Robert 2
Report this Post07-04-2014 08:44 PM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Was an injector shorting .
