  3800sc Lines from LIM and TC.
3800sc Lines from LIM and TC. by 87FieroSport
Started on: 06-01-2014 07:34 PM
Replies: 10 (256 views)
Last post by: fierogtx on 06-03-2014 02:02 AM
87FieroSport
Report this Post06-01-2014 07:34 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1986 Fiero GT, putting in a 1999 GTP 3800 Series 2 Supercharged motor...
Now about the lines coming out of the LIM and the timing cover, do I go ahead and plug those or?...
I plan to get a modified T'stat housing, but heard years differ.
87FieroSport
Report this Post06-02-2014 11:04 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
fierogtx
Report this Post06-02-2014 11:19 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
you need to search in the forum there is hundreds of thread about that .unfortunately i speek french and me too building a 3800 sc and sometimes it is really hard to understand . you can have too many configuration (depends on if you keep the alternator bracket or not , uses modded fiero t-stat housing .....) but if im not wrong you have two cooling model on fiero the 84-86 who have a return for the heater core and the 87-88 who have a return that goes to the passenger side coolant pipe. when you have a 87-88 and you uses a modded fiero housing that have a small tube onder the thermostat you can plug these two holes ( lim and water pump timing cover ) and you put a hose from the small tube to the heater feed line . because you have the 86 maybe you need to retain one of these 2 holes for the return for the heater core . maybe another who can help you or try the search forum
87FieroSport
Report this Post06-02-2014 11:26 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
With my searching I've only found 87-88 installs.
Any '86 are very vague.
I'm losing the stock Alt bracket and going with a low mount,
A/C still in the same place.
I don't mind plugging one and tapping another, but it'd
Be nice to know which to tap and which to plug.
fierogtx
Report this Post06-02-2014 11:30 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
i saw many were talking about the 84-86 in the search click for entire forum + archives and dont write years just write 3800 coolant and you will have to search for a lot of threads i know i saw a couple about the 86
bomluuk
Report this Post06-02-2014 12:16 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took the easy way on my swap. I didn't plug any holes and just ran 2 coolant hoses from the engine to the heater core lines.
87FieroSport
Report this Post06-02-2014 12:47 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well searching on my phone at work isn't my priority.
It would be nice if someone just said,
"To save time and hassle just tap the LIM and/or TC and thread in a -/- NPT nipple to run x line"
I'm never a dick and tell people to use the search function
Unless is an insanely obvious question.
Purple86GT
Total ratings: 62
Report this Post06-02-2014 04:52 PM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in the process of doing mine. (86 GT) If I'm not mistaken, it's 3/4 NPT tap. I read that you should check the irragation section of most hardware stores to find the 3/4 NPT to barb fitting thatwould work with heater core hoses.
good luck!
bomluuk
Report this Post06-02-2014 05:56 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nobody is trying to be a dick.
Its generally understood that when you go to a forum, you search first. Call it forum etiquette. In this case, there is 15 years of information. Thats a lot.
Also, did you ever stop to think about everyone else's priorities?
Having said that, I hope you get your answer.
jaybug56
Report this Post06-02-2014 11:14 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yup. An insanely obvious question
You have been ignored
[This message has been edited by jaybug56 (edited 06-10-2014).]
fierogtx
Report this Post06-03-2014 02:02 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
first let me tell you a thing from a guy that speek french and not perfectly english but i will give you a life lessons i had 2 works from the last 11 years and i have other priorities more than you have first im not a dick i tried to help you second i do my homework and do the job correctly and search for all subject about the 3800 to read multiples opinion and technical info. dont be shy to use the search function your brain will freeze up if you dont keep it working
[This message has been edited by fierogtx (edited 06-03-2014).]
