  88 Fiero lower ball joint
88 Fiero lower ball joint by Imnuts
Started on: 05-30-2014 09:23 AM
Replies: 2 (444 views)
Last post by: Imnuts on 05-30-2014 10:19 AM
Imnuts
Report this Post05-30-2014 09:23 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
This maybe too many subjects for one post but here it goes.
1.) Is the lower ball joint made with a curve or bent in it? When I went to remove the nut it was lose and ball joint shaft rotated inside the spindle making the bottom of it move in and out about ¼ inch.
2.) I also noticed my control arm oscillating as I am spinning the lower control arm bolts as I am trying to break them free. Should they be straight bolts or they offset for alignment purposes? As you can tell I have not been able to free them yet and I am thinking they are going to have to cut them off to remove the control arm. Any suggestion would be greatly appreciated.
3.) Also I need a source for buying new replacement bolts.
fierosound
Total ratings: 286
Report this Post05-30-2014 09:40 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what you're saying, I'd say that front wheel took a hard hit to a curb or something. It the control arm OK?
I didn't find a source for bolts. You'll have to match them up with automotive Grade 8 bolts (or better) at an auto store.
Control arms http://fierostore.com/Product/Search.aspx?p=1
Ball joints http://rodneydickman.com/ca...ndex.php?cPath=26_43
Calgary time/temp
[This message has been edited by fierosound (edited 05-31-2014).]
Imnuts
Report this Post05-30-2014 10:19 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply.
Everything seems to look normal. I wanted to make sure I can just buy normal hardened straight bolts for the lower control arm and they were not made special for alignment reasons. I already ordered upper and lower ball joints from Dickman's and control arm bushings from Fiero Store.
