  which pins to trick 3800 ecm for crank variation relearn?
which pins to trick 3800 ecm for crank variation relearn? by LoW_KeY
Started on: 05-29-2014 10:04 PM
Replies: 5 (409 views)
Last post by: olejoedad on 05-31-2014 11:33 AM
LoW_KeY
Total ratings: 150
Report this Post05-29-2014 10:04 PM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have which pins on sheet, just want to make sure I get the right ones when I head to the shop tomorrow. I'm not sure if they're numbered or what? found a place that would do it $10 bucks. One place told me $50!
3800 SC/IC Formula whines more than your girl... 12.7@113 330 HP/430TQ
08 Cobalt SS TC - ZZP tuned, K&N SRI, 6k HID's 13.31@107
solotwo
Total ratings: 62
Report this Post05-29-2014 10:16 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope it works out for you.
LoW_KeY
Total ratings: 150
Report this Post05-29-2014 11:58 PM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
makes 2 of us this resolves it end of June new tires and Michigan mile here I come
if not to zzp I go, but the whole random misfire leads me to believe this as did darth fiero. I'll post back
Total ratings: 290
Report this Post05-30-2014 08:52 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clear 16 & 18
Report this Post05-31-2014 10:25 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do the crank relearn via the HP software/laptop route. I don't believe that you can do it by jumping pins at the OBDII connector.
Report this Post05-31-2014 11:33 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
C-16 & C-18 need to be grounded to make PCM think the auto trans is in Park. Also need 12v from brake switch to be present, and the then brake depressed removing the 12v on B-30(?).
You can not cause CASE learn by jumpering, it must be commanded externally, but the above conditions must be satisfied to fool the PCM that there is an auto trans present.
