  can you identify this?
can you identify this? by LB23
Started on: 05-26-2014 08:51 PM
Replies: 5 (394 views)
Last post by: Csjag on 05-27-2014 07:25 AM
LB23
Report this Post05-26-2014 08:51 PM Click Here to See the Profile for LB23Send a Private Message to LB23Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am currently doing a driveway oil change and when i went to remove the oil filter i got stuck by this braided line that I have no idea what it supposed to run to.
Csjag
Report this Post05-26-2014 09:01 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
How long have you had the car. it looks like someone capped off a line that used to go to something, maybe a oil cooler or remote oil filter.
Spoon
Total ratings: 61
Report this Post05-26-2014 09:06 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
make-shift oil pan vent?
LB23
Report this Post05-26-2014 09:46 PM Click Here to See the Profile for LB23Send a Private Message to LB23Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have had the car about a year now but was parked all winter and before that only put about 50 miles on it. If its not a stock part Ill just guess that its something the PO did to hide the massive blowby issue that failed so he capped it off.
Thanks for the reply's guys.
tesmith66
Total ratings: 135
Report this Post05-27-2014 06:13 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Turbo oil drain? Not stock, of course.
Csjag
Report this Post05-27-2014 07:25 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the engine may have a lot of dirty oil buildup. I am not affiliated with this product but I used it on the recommendation of another forum member, go to auto-rx.com and read up about the product. I had leaking rear axle seals and it cured them enough that I was able to replace the motor oil with GM synchromesh fluid and now have no leaks. I am in the process of ordering more to use in the engine to clean the engine, rings, etc. and condition the seals. It is a gentle cleaner and conditioner. I know testimonials can be bogus but I think its worth a try to avoid opening up the engine.
