  Another F*** electrical problem
Another F*** electrical problem by alejandrissimo
Started on: 05-24-2014 01:59 PM
Replies: 8 (261 views)
Last post by: phonedawgz on 06-01-2014 12:06 PM
alejandrissimo
Report this Post05-24-2014 01:59 PM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, me again.
So the 2m4 is partially working, I mean, I can start and go from here to there BUT if I drive over bumps (the streets from my town are sh*t) I erratically get chech engine light and when the light is ON (usually blinking like crazy) the engine start to die, but if I give it some gas I managed to keep it running.
Now, other thing I notice is I start the engine without give it gas it goes shout down instantly, if I start the engine and keep the revs a little high, the engine keeps running.
So I thing the problem is some poor contact on the lines where the fuel pump is connected, maybe a pigtail?
Btw, when the engine on, the check engine light gives me no codes, only when I drive over bumps.
The engine light works also. (Always on with key on, engine off)
What do you suggest to start checking?
seajai
Total ratings: 51
Report this Post05-24-2014 02:41 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start by checking all of your grounds. Look under the hood and in the engine bay. Make sure they are clean, free from rust, and tight. If bumps are causing electrical problems you have a bad connection somewhere. Try moving the wire harnesses around while the engine is running, if a malfunction occurs this can help pinpoint a specific area to look.
Total ratings: 290
Report this Post05-24-2014 02:49 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
My guess is a that you have an 84 and you have a loose nut on the positive battery cable at the starter.
If you are 85+ check the nuts on the power distribution posts located under C500 (big electrical connector near the battery)
Both of these are live with the battery connected so make sure you disconnect the battery before you put a wrench on them.
Also electrical problems do not copulate.
84fiero123
Total ratings: 325
Report this Post05-24-2014 07:35 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have nothing except,
"I would rather pound my balls flat with a sledge hammer than hunt down an electrical problem."
Favorite saying
Steve
Neils88
Total ratings: 56
Report this Post05-24-2014 08:02 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Favorite saying
Steve
Going to need copious amounts of alcohol to get that image out of my head, Steve
Definitely sounds like a loose connection. Fiero's seem to have issues with loose grounds, so that would be good place to start.
alejandrissimo
Report this Post05-24-2014 09:21 PM Click Here to See the Profile for alejandrissimoSend a Private Message to alejandrissimoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Crap, you was right man, a loose nut at the starter, now the fiero is not shouting down anymore, btw it's an 86
Also the check engine light when driving over bumps persist so I will check every damn connector.
Is there a way to get a code in real time?
Thanks.
84fiero123
Total ratings: 325
Report this Post05-24-2014 11:17 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Glad I could help you start the weekend off early. by the way I made a T shirt that says something like that only about rear drum brakes.
Thanks.
clear the codes, by disconnecting the battery for a few min, it may have been caused by the loose battery terminal and may never start again.
Steve
[This message has been edited by 84fiero123 (edited 05-24-2014).]
Fiero.1984
Report this Post05-31-2014 09:19 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure that the spark plug wires are not touching the exhaust manifold. Look at the spark plug wires and if you see an melting on the wires. I had mine ground against the exhaust manifold and burnout my ECM.
Total ratings: 290
Report this Post06-01-2014 12:06 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Buy my scanner cable, use TunerPro RT and you can scan both the inputs, and the error codes in real time.
http://reddevilriver.com/aldl.html
It's the 12 pin USB version you need with the Fiero.
Not in real time but you can read the codes with a paperclip
