  The Other Mall
  vw b4 passat tdi
vw b4 passat tdi by anthonyelectric
Started on: 07-31-2017 05:42 PM
Replies: 0 (138 views)
Last post by: anthonyelectric on 07-31-2017 05:42 PM
anthonyelectric
Report this Post07-31-2017 05:42 PM Click Here to See the Profile for anthonyelectricSend a Private Message to anthonyelectricEdit/Delete MessageReply w/QuoteDirect Link to This Post
READ ENTIRE AD BEFORE RESPONDING, I'VE MADE A LIST OF WHAT'S GONE.
**I'm going to begin throwing things out.
UPDATE - 7.30.17
Brand new in box
Emblem - 20 plus ship
KYB strut boots (X3) - 20 plus ship for lot
Reverse light sleeve - 10 plus ship
Reverse light switch - 15 plus ship
Prices on stuff (all prices are plus shipping):
2 pairs of rear headrests: 18.95 each pair (this is a just-pay-shipping part!)
Window switch $5
Defroster switch $5
Flywheel. $65
Air box bottom only $20
Oil pan. $20
Wiper arms: 15
Upper engine sound cover: 30
1 external front passenger door handle: 15
1 internal tan diver's side door handle: 15
*TAKE EVERYTHING FOR 100 plus shipping/ I can help you if local to Albany, NY !!!*
Already sold:
NON SUNROOF cars
Side Marker lights
"Dummy" fog lights
Turn signals
EUC
Main Wiring harness engine to fuse box
Cluster
Grille
Headlights
Headlight frame
Headlight switch
Interior door mirror covers
Door weatherstripping
Interior Brake light switch and cover
ABS Module, booster, master cylinder, and bracket
Power Steering pump/Rack/shaft/hoses/reservoir
Rear Trunk latch/lock/vacuum and electric modules (still have wiring harness and vacuum module)
Shifter and cables
Pedal Cluster
Heater/A.C switches/assembly (still have display)
Floor Mats
Steering Wheel
Both upper and lower "Clam shell" for steering column (still have column)
Front and Rear belly pans
All hard fuel lines from IP to injectors
All coilover assemblies
All exhaust components
CNT 5 speed transmission
Rear glass top trim
All interior map lights
All cupholders
Fenders
Injectors
Injection Pump and bracket
Starter
Crankshaft
Block
Intercooler with SOME pipes (Still have many black/silver pipes, hoses)
Slave Cylinder and all hardlines
Entire top portion of motor (head, manifolds, turbo)
Valve cover (still have oil cap)
all portions of timing belt cover
inlet pipe
Shifter and boot
PS pump, hard line to res., and bracket
Alternator and pulley
A/C Compressor and pulley
Turbo inlet pipe (have many others)
Radiator and all mount/support/front motor mount bar
All coolant hoses
Fans
Top of Air Box (still have bottom)
Dash (but still have some inserts and switches)
REAR seatbelts (but still have fronts)
Radio
Both lower control arms
K-frame and sway bar
Driver's brake line (still have Passenger's)
Driver's axle/spindle/caliper (still have passenger's)
HVAC box
Wheelwell liners
crossmember
Water pump/housing/all hoses
mirrors
air bags
Negotiable on prices if you are purchasing multiple parts
***Also - looking for a MK2 Jetta parts - would LOVE to trade/partial w cash - would love to discuss! ***
