  The Other Mall
  Passat TDI 1997 AHU part out
Passat TDI 1997 AHU part out by anthonyelectric
Started on: 12-01-2016 07:22 AM
Replies: 3 (226 views)
Last post by: anthonyelectric on 02-04-2017 10:28 PM
anthonyelectric
Report this Post12-01-2016 07:22 AM Click Here to See the Profile for anthonyelectricSend a Private Message to anthonyelectricEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brand new in box
Bosch water pump and gasket - 20 plus ship
Emblem - 20 plus ship
KYB strut boots (X3) - 20 plus ship
Reverse light sleeve - 10 plus ship
Reverse light switch - 15 plus ship
Prices on stuff:
Hood $80
Complete pair of front doors $100
Air bags (2) $50 for both
Dashboard $50
Window switch $5
Defroster switch $5
Radiator (2) $40 for both
A/C condenser (2) $40 for both
Block (now in pieces, ask for parts!) $100
*TAKE EVERYTHING FOR 400 plus shipping/ I can help you if local to Albany, NY !!!*
Will entertain offer on multiple parts in one shipment
I am new to VWs and have heard VERY positive things about this site. I am looking forward to helping some B4 TDI people get what they need.
Thank you for looking
Already sold:
NON SUNROOF cars
Side Marker lights
"Dummy" fog lights
EUC
Wiring harness
Cluster
Grille
Headlights
Headlight frame
Interior and Exterior door handles
Interior door mirror covers in black
Interior Brake light switch and cover
ABS Module, booster, master cylinder, and bracket
Power Steering Rack/brackets/shaft/hoses/reservoir
Shifter and cables
Pedal Cluster
Slave Cylinder and all hardlines
Rear Trunk latch/lock/vacuum and electric modules
Entire top portion of motor (head, manifolds, piping, turbo)
Radiator mount/support/front motor mount bar
Heater/A.C switches/assembly
Intercooler
Floor Mats
A/C Compressor
Steering Wheel
Rear plastic under-gas tank pan
Headlight switch
All hard fuel lines from IP to injectors
Both upper and lower "Clam shell" for steering column
All coilover assemblies
All exhaust components
CNT 5 speed transmission (still have clutch plate and block!)
Rear glass top trim
one pair of turn signal lenses (still have another pair!)
All interior map lights
All cupholders
Injection Pump bracket
Fenders
Negotiable on prices if you are purchasing multiple parts
***Also - looking for a MK2 Jetta parts - would LOVE to trade/partial w cash - would love to discuss! ***
anthonyelectric
Report this Post12-01-2016 07:24 AM Click Here to See the Profile for anthonyelectricSend a Private Message to anthonyelectricEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, Still parting out a 97 Passat with an AHU engine . The car had 195K on it. Here is a list of parts I still have along with some others I had laying around. If you don't see what you need, pm me. However most of the major items have been sold. These prices don't include shipping. Thanks
Flywheel. $75
Harmonic balancer. $40
4 pistons. $50 (two are destroyed)
4 connecting rods. $100
Innercooler with pipes. sold
Air box. $40
Airbox to turbo pipe. $20
Pulleys. $15 each
Valve cover. $15
Oil pan. $20
Battery tray. $25
Mass air flow sensor. $30
Coolant flanges. $10 each
Center console. $40
air bags, cover, controller $65
already sold:
Injectors
Injection Pump and bracket
Head
manifolds
anthonyelectric
Report this Post02-04-2017 10:26 PM Click Here to See the Profile for anthonyelectricSend a Private Message to anthonyelectricEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brand new in box
Bosch water pump/gasket/housing/hoses - 40 plus
KYB strut boots (X3) - 20 plus ship for lot
Prices on stuff (all prices are plus shipping):
2 pairs of rear headrests: 18.95 each pair (this is a just-pay-shipping part!)
Window switch $5
Defroster switch $5
Flywheel. $65
Air box bottom only $20
Oil pan. $20
air bags, cover, controller $55
each AHU brackets (I have most of them!) 45
Wiper arms: 15
All coolant hoses: 65
complete interior of trunk (plastic, carpet): 35
Upper engine sound cover: 30
1 external front passenger door handle: 15
1 internal tan diver's side door handle: 15
*TAKE EVERYTHING FOR 250 plus shipping/ I can help you if local to Albany, NY !!!*
Already sold:
NON SUNROOF cars
Side Marker lights
"Dummy" fog lights
Turn signals
EUC
Main Wiring harness engine to fuse box
Cluster
Grille
Headlights
Headlight frame
Headlight switch
Power Steering pump/Rack/shaft/hoses/reservoir
Rear Trunk latch/lock/vacuum and electric modules (still have wiring harness and vacuum module)
Shifter and cables
Pedal Cluster
Heater/A.C switches/assembly (still have display)
Floor Mats
Steering Wheel
Both upper and lower "Clam shell" for steering column (still have column)
Front and Rear belly pans
Rear glass top trim
All cupholders
Fenders
Injectors
Starter
Crankshaft
Block
Intercooler with SOME pipes (Still have many black/silver pipes, hoses)
Entire top portion of motor (head, manifolds, turbo)
Valve cover (still have oil cap)
all portions of timing belt cover
Shifter and boot
PS pump, hard line to res., and bracket
Alternator and pulley
A/C Compressor and pulley
Turbo inlet pipe (have many others)
Radiator and all mount/support/front motor mount bar
Fans
Top of Air Box (still have bottom)
Dash (but still have some inserts and switches)
REAR seatbelts (but still have fronts)
Radio
Both lower control arms
K-frame and sway bar
Driver's brake line (still have Passenger's)
Driver's axle/spindle/caliper (still have passenger's)
anthonyelectric
Report this Post02-04-2017 10:28 PM Click Here to See the Profile for anthonyelectricSend a Private Message to anthonyelectricEdit/Delete MessageReply w/QuoteDirect Link to This Post
anthonyelectric
Member since Mar 2015
Brand new in box
Window switch $5
Defroster switch $5
Flywheel. $65
Oil pan. $20
Wiper arms: 15
Already sold:
NON SUNROOF cars
Side Marker lights
"Dummy" fog lights
Turn signals
EUC
Cluster
Grille
Headlights
Headlight frame
Headlight switch
Shifter and cables
Pedal Cluster
Floor Mats
Steering Wheel
Rear glass top trim
All cupholders
Fenders
Injectors
Starter
Crankshaft
Block
Shifter and boot
Fans
Radio
