  Other Cars
  Battery change in 14 ford Escape
Battery change in 14 ford Escape by davylong86
Started on: 11-04-2018 12:12 PM
Replies: 4 (313 views)
Last post by: ZCR1 on 01-25-2019 05:02 PM
davylong86
Report this Post11-04-2018 12:12 PM Click Here to See the Profile for davylong86Send a Private Message to davylong86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Piece of cake! remove wipers, take off lower windshield panel then remove the brake reservoir, remove the lower drain pan, remove two covers, disconnect out side ground then the positive cable, pull out so you can reach negative cable, then clean and brush off all component's that you cant get to because all things mentioned above. Then hope you get the right battery from (Auto Zone) NOT! Total time, 3hrs 15min. Note: make sure to mark your wiper position before removing, cost me 15min on that adjustment. Fiero battery, 12min job. Just saying.
RWDPLZ
Total ratings: 305
Report this Post11-29-2018 03:31 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I used to work at an auto parts store, people would ask if we could install a battery for them, and we would tell them we had to go outside and look at it first. This is why. People with GM Minivans were always pissed when you told them no, because they had usually gotten a quote from a mechanic or dealer with substantial labor.
Passat sounds similar to what you describe
wgpierce
Report this Post01-23-2019 08:17 PM Click Here to See the Profile for wgpierceSend a Private Message to wgpierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try a Lotus Elise. Have to remove the entire back half of the car to get to it. 5K AUD job here!
johnt671
Report this Post01-24-2019 08:28 AM Click Here to See the Profile for johnt671Send a Private Message to johnt671Edit/Delete MessageReply w/QuoteDirect Link to This Post
Those make my 98 Sebring convertible look easy. I only have to pull the drivers side front wheel and the inner fender to change the battery.
ZCR1
Report this Post01-25-2019 05:02 PM Click Here to See the Profile for ZCR1Send a Private Message to ZCR1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Our Durango's battery is under the front passenger seat!
