  Other Cars
  2006 Pontiac Torrent - Equanox clone
2006 Pontiac Torrent - Equanox clone by Jake_Dragon
Started on: 02-11-2017 06:51 PM
Replies: 5 (203 views)
Last post by: Jake_Dragon on 02-24-2017 06:07 PM
Total ratings: 400
Report this Post02-11-2017 06:51 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an issue with an 06 Torrent. The blower quit working.
Things I have checked and replaced
Resister pack is new
HVAC controls have been replaced, found a bad wire but it wasn't the issue
Motor is good, pulled it and it comes on fine when I put power to it.
I have enough power to the motor to light up a trouble light on the plug only on low and medium, on high I have no power.
It seems like either a ground or fault on the power. The light could just be feed back from the other part of the circuit.
I am fed up for today and thought I would ask here and see if anyone had any ideas.
E.Furgal
Total ratings: 278
Report this Post02-16-2017 07:01 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
The motor power (speed) should be a circuit board..
I know it's seems silly but pull the fuse and look at it..
Total ratings: 400
Report this Post02-18-2017 11:18 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did pull the fuses and made sure that they were good
I have power on the red and white wire but it drops as soon as I put a load on it
I'm going to bypass the connector coming from under the hood because it looks a little sketchy It's not melted
But I can see where it's been getting hot
They definitely cut corners on these vehicles
Total ratings: 400
Report this Post02-19-2017 01:50 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I spliced the power wire coming in from under the hood at the main connection and I now have a working blower motor
Total ratings: 463
Report this Post02-24-2017 04:26 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Silverados were bad about burning up resistor packs AND the plug where the pack plugs in.
Total ratings: 400
Report this Post02-24-2017 06:07 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same parts bin
2 plugs and about a foot of wire to be safe
