  Other Cars
  TC, ABS Brake light all on after dead battery '08 Torrent.
TC, ABS Brake light all on after dead battery '08 Torrent. by Fosgatecavy98
Started on: 12-31-2014 01:09 PM
Replies: 2 (104 views)
Last post by: jaskispyder on 01-08-2015 12:09 PM
Fosgatecavy98
Report this Post12-31-2014 01:09 PM Click Here to See the Profile for Fosgatecavy98Send a Private Message to Fosgatecavy98Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since its 16F and high winds I was due for car issues. My rear wiper on my torrent has been dead but I went to the car wash and manually put it straight so the car wash would actually wash the entire window. I think thats what drained my battery.
Anyways I jumped it with my Fiero and I did it with the absolute minimum battery power to get it to catch. Now when I turn it on, everything is normal except the traction control dash indicator stays on and the ABS and hand brake light come on after a few moments. Looking for some thoughts while I am inside warming up. Everything worked fine before this happened.
Total ratings: 463
Report this Post01-01-2015 11:05 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
My G6 used to throw random TC and ESC (Electronic Stability Control) lights.
They were caused by an intermittent "out of range" reading on the intake air temp sensor. I never got a MIL until the code for the IAT sensor was set hard. Apparently, a failure in the engine controls caused the PCM to take the other systems offline as well.
As soon as I repaired the broken wire in the IAT circuit, the TC and ESC lights went away and haven't returned.
Readers Digest version... Get it scanned and see if you have any other codes. It may be a coincidence.
[This message has been edited by Raydar (edited 01-01-2015).]
jaskispyder
Total ratings: 205
Report this Post01-08-2015 12:09 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Solve this issue? Could be the BCM being thrown off by the battery issue.
