  Other Cars
  86 ramcharger HELP! (Page 2)
86 ramcharger HELP! by zetabird
Started on: 06-09-2014 08:18 AM
Replies: 42 (455 views)
Last post by: zetabird on 09-19-2014 03:35 PM
tesmith66
Total ratings: 135
Report this Post09-19-2014 06:29 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wait a sec...it has an electric pusher pump ahead of a mechanical pump on the block? It also has a return with a pressure relief valve built into the filter? And a carb? Am I deducing this correctly?
If the above is true, I would ditch all of that and just run a mechanical pump and a straight filter. Go old school.
KurtAKX
Total ratings: 128
Report this Post09-19-2014 11:13 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Tstang429:
Ok this is gonna sound weird drive around with the gas cap off see if it makes a difference. Maybe a vents not working or blocked off and you getting a vacuam.
I've had the mechanical fuel pump in my old Caprice suck the fuel tank halfway flattened when there was a vent malfunction. I opened the gas cap and I heard a Kaa-BONG!! as the tank popped back.
zetabird
Report this Post09-19-2014 03:35 PM Click Here to See the Profile for zetabirdSend a Private Message to zetabirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
i had added an electric pump on the fender an old dodge tech around here said there known for the centric on the end of the cam that drives the pump wearing down and not building pressure. anyway the pump locked up i pulled it off and dumped some heat in it and off it goes again.... dumb truck... now i got some vacume crap to get rid of and lots of wireng but it runs better than it has in a long time now
