  Other Cars
  '99 Tahoe, rear brake drum issue. Need help
'99 Tahoe, rear brake drum issue. Need help by hdryder
Started on: 06-07-2014 10:28 PM
Replies: 2 (79 views)
Last post by: Monkeyman on 06-08-2014 11:47 PM
hdryder
Report this Post06-07-2014 10:28 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know if any group can help me with vehicle repairs, it would be Pennock's Fiero Forum.
I just replaced both rear drums, shoes, wheel cylinders, and new rear brake hardware. The passenger side is working great. The driver's side is dragging and will get very hot in a very short time.
On the driver side, the front shoe is moving inward when it is pushed out by the wheel cylinder. Then it hangs up on the top edge on the top fixed anchor mounting plate.
Any ideas what may be causing this to occur, and how I can correct it?
I have compared everything I see to the passenger side, but do not yet see a difference.
Thank you for the help.
carnut122
Total ratings: 83
Report this Post06-08-2014 07:55 AM Click Here to See the Profile for carnut122Send a Private Message to carnut122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe a little brake lube applied to
"rubbing" surfaces? Are the springs not strong enough to retract the shoe?
Is the parking brake released all of the way?
[This message has been edited by carnut122 (edited 06-08-2014).]
Monkeyman
Total ratings: 180
Report this Post06-08-2014 11:47 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the shoes on backwards?
