  Other Cars
  2001 SL1 random super high revving
2001 SL1 random super high revving by FieroCustom
Started on: 11-28-2012 10:02 PM
Replies: 2 (96 views)
Last post by: Monkeyman on 11-29-2012 04:49 AM
FieroCustom
Report this Post11-28-2012 10:02 PM Click Here to See the Profile for FieroCustomClick Here to visit FieroCustom's HomePageSend a Private Message to FieroCustomEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, this car is driving me nuts. Every once in awhile the engine will rev up while your foot is off the pedal. It has slowly been getting worse, tonight revving to about 3500rpm. So you let off the gas and the car continues to accelerate. Kinda hairy if you're trying to brake and the engine is fighting you to a stop. The SL1 is being a bad car. Any ideas?
Thought it was the IAC, replaced that.
We pulled the cruise fuses tonight to verify it was not the cruise control trying to engage. Will drive it to/from work tomorrow to see if it is cruise control issue.
Thinking about looking for vacuum leak tomorrow in the daylight.
Would a fault with the air pump system cause a high idle issue?
What about a fault with a transmission solenoid?
Blacktree
Total ratings: 350
Report this Post11-29-2012 12:54 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would check the vacuum hoses to see if something is wrong. Also, the EGR valve is a common failure point on these cars. It can stick open, and cause the symptoms you described. If the EGR valve is gunked up, you can try cleaning it out with carb cleaner, and see if that helps.
The AIR system just pumps air into the exhaust. So it shouldn't affect the running of the engine. The transmission solenoid shouldn't affect the idle like that, either.
Monkeyman
Total ratings: 182
Report this Post11-29-2012 04:49 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
What he said. Vacuum hoses, EGR or a filthy throttle body.
