  Other Cars
  Help with 98 Cavlier, maybe a Passlock problem
Help with 98 Cavlier, maybe a Passlock problem by FieroGT42
Started on: 10-30-2012 02:17 PM
Replies: 0 (68 views)
Last post by: FieroGT42 on 10-30-2012 02:17 PM
FieroGT42
Total ratings: 67
Report this Post10-30-2012 02:17 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
It had an intermittent starting problem, so I installed a starter button bypassing the ignition switch. Faster & easier for me. It worked perfectly for years, so I'm pretty sure that was a bad switch, not a Passlock problem.
Now it has a new problem where it dies and then will not crank. Removing the battery ground resets something so that it starts again, but it will eventually die again.
Is it the key resistance sensor? Will this work? http://www.justanswer.com/c...sslock-car-runs.html
