What size turbo?
Going to need a looser converter to get up around 2800-3000 rpm to spool regardless of other tricks. Then the brakes need to be able to hold the car back as the torque increases as turbo spools. Even if you don’t make boost on the line a looser converter will flash higher and help make boost faster.
Dark horizon used nitrous to help spool his turbo, if you want to try that.
Not much available for 2-steps on stock pcm, I can’t even recommend the one I have as it was a battle to make it work, I had to send it back for modification. Other option is the MSD ignition box but it is unreliable.
IAT mod allows you to cut timing while spooling the turbo but requires pcm programming to work. Takes experimenting to find right timing, so you really need to be able to do the tuning yourself.
Search for “ iat timing mod” online, info is out there, regardless of GM platform, the idea is the same.
10.007 @ 135.54MPH. <-- Video
Best 60' 1.42
Best mph 138.82
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 140lb springs, comp pushrods, HV3, stock L32 bottom end and heads.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
