| quote | Originally posted by theogre:
[QUOTE]Originally posted by Dennis LaGrua: Do you believe that someone is going to remove your tail light housings and look inside at the bulbs? . Not going to happen. I run these LED lamps and they are somewhat brighter than the 1157 bulbs. This all sounds like a completely manufactured a problem when there is none. Furthermore all new vehicles use LED tail lights and these LED's also look stock.. There is no problem. |
ooo you claim looks like stock... yet likely didn't even bother trying to do any brightness test or even clean/fix the internals of fixtures making the Taillights "dim."
1. In most places can simply Fail or Ticket you for the iffy lights because are too bright or dim or cause glare or have wrong color. Before LED Many use Halogen and other "Brighter" bulbs w/ high color temp causing same problem or melt/burn the fixtures. Plus hotter bulbs often have a Very Short Life even w/o other problems. 2357 (Often sold by RD etc. as light "upgrade.") has way shorter life then 1157 or 2057 and just die for that and can generate a Fail/Ticket.
2. OE LED for newer vehicles Do Not have Replaceable LED. These are "DOT Approved"
Only for a specific vehicle at a Lab Certified by USDOT/NHTSA.
These LEDs are Built Into One Unit and Not Serviceable even by Dealers.
Same construction for OE LED 3rd Brake light for Decades now. Worse Often you have pull out trim like pulling Fiero B pillar Speakers that eats Time that you pay in Labor Cost on top of High $ Part Cost.
3.
But LED last way longer... Sadly this is often a
No even for OEM units in New cars. "Best" LEDs are often Built to Cost not long life because manufacturing to shave pennies or less per unit. Aftermarket parts more so in most cases. This Is Why Prius and a lot more have part dead LED Taillights etc. Even at Home many LED are "over driven" to slice number on LED chips per "bulb" to make and sell at razor thin margin. This is why most CFL sucked and failed fast and now mostly gone from everywhere. Good CFL did exist but can't compete on price.
Even if you find ones built for long life, the fixtures often don't move enough air to cool them or air is hot to start then LED chips and other parts on/in them still cook and die. Is why many enclosed fixtures for home cooked CFL and now LED.[/QUOTE]
The direct plug in COB LED tail lights are brighter to the eye test but don't appear to be drastic in light output. They run cool. I guess you could say that my Corvette light panel is also not DOT approved but it doesn't seem to bother law enforcement. I run a classic car that is exempt from state inspections. The short of it is that as long as you are not using lights with a blinding output like the Chinese headlights, I believe that what I am doing is within reason and won't be noticed.
