  Anyone tried the Mookeeh shocks/struts on eBay?
Anyone tried the Mookeeh shocks/struts on eBay? by Craig71188
Started on: 01-08-2021 07:51 AM
Replies: 2 (562 views)
Last post by: Craig71188 on 01-08-2021 10:01 AM
Craig71188
Report this Post01-08-2021 07:51 AM Click Here to See the Profile for Craig71188Send a Private Message to Craig71188Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I found a thread on a Mookeeh exhaust system, but nothing on their shocks/struts. I have contacted them through eBay and they know little to nothing beyond what is listed in their add. They claim they have shock/strut package that is 1" shorter than stock and 20%-30% stiffer. I like the KYB Gas-A-Just fronts on the '88, but there is no comparable rear option. I have a set of Koni's, but we take a major points hit to run them on the race car. The Mookeeh pieces are almost cheap enough to just buy a pair and test, but I thought I would see if there was anyone with any experience with them first.
Add for the '84-'87 set:
https://www.ebay.com/itm/Mo...e:g:YPcAAOSwpzdWsDWC
Add for the rears only they created so I could buy them to try on the '88:
Report this Post01-08-2021 09:16 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think there is a mini van application where the strut is a little shorter, this is probably the application they are targeting. Pretty sure it is a stock strut for a heavier application.
If you want it for the shorter length, have you flipped the strut bushing hat? Doing so places the top of the strut 1" higher relative to the strut tower and gives you 1" more suspension travel in compression.
Craig71188
Report this Post01-08-2021 10:01 AM Click Here to See the Profile for Craig71188Send a Private Message to Craig71188Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not so much concerned with length, more about ability to damp a higher than stock spring rate effectively.
