  Recommendations for good affordable source for fire extingishers?
Recommendations for good affordable source for fire extingishers? by 2.5
Started on: 11-04-2020 12:06 PM
Replies: 4 (327 views)
Last post by: Australian on 11-20-2020 03:52 AM
Report this Post11-04-2020 12:06 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
ABC type seems best. Mine are getting old. Some for house, garage, and cars.
Order online? Retail store? Some folks recharge them it seems too.
Report this Post11-04-2020 05:01 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try use search. Been covered many times.
quick notes:
Recharging FE for people w/o contract w/ local Fire Protection Equipment co is not happening even when you have rechargeable units and most home users do not have them. Recharge cost more then most think plus many are "out of date" for DOT rules and causes more issues and higher cost even if can recert the tank.
IOW Most FPE co's Do Not recharge any Plastic valve and many metal valve units you get from Retail stores including online. Not even 15# or bigger "Dry Chem" units.
DIY recharge w/ compressed air is a no no. Might seem to work but Many "Dry Chem" will turn to "concrete" exposed to air. Most compressors output wet air, oily air or both and react w/ the chem's.
If you have Kidde units... check for Recall on many of them. see https://www.fiero.nl/forum/Forum6/HTML/121743.html
[This message has been edited by theogre (edited 11-04-2020).]
cvxjet
Report this Post11-04-2020 07:16 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a small First Alert extinguisher that I bought at Walmart- It is available at both Amazon and Walmart for $16.99.....
[This message has been edited by cvxjet (edited 11-04-2020).]
Todd00000
Report this Post11-05-2020 10:11 PM Click Here to See the Profile for Todd00000Send a Private Message to Todd00000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check these out.
https://elementfire.com/
Todd
Australian
Report this Post11-20-2020 03:52 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anything to do with fire fighting should be cheap and generally is as i sell pumps etc and it generally is cheap.
