Hey all. I pulled my Held/HT tubular suspension off the '88. I sandblasted and sent everything out for powdercoat. I am reassembling the front suspension and noticed, there arent any bump stops. '88s have bolt on bumps stops which makes life way easier to lower the front vs the 84-87. However, I don't remeber removing the bump stops and I dont actually see any provisions to mount them in the lower a-arms.
TLDR Questions:
What did you do about bump stops in the Held/HT
1988 front suspension?
FSM shows a TQ spec for UCA to paddle bolts but no spec for UCA to shaft. I went with 32. What did you use?
Things I noticed. At first glance the A-arms seem symmetrical. The uppers are. The lowers could have been had they drilled a hole on each corner of the plate for the swaybar end link. It would have been so simple. I wonder why they didn't?
