  Failed inspection - Repair, replace or ugrade
Failed inspection - Repair, replace or ugrade by MacDee
Started on: 06-16-2020 11:01 PM
Replies: 9 (375 views)
Last post by: JohnyWalter on 07-31-2020 07:59 AM
MacDee
Report this Post06-16-2020 11:01 PM Click Here to See the Profile for MacDeeSend a Private Message to MacDeeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a 86 GT that I love to drive. But it failed its Vermont inspection with these comments.
E brake doesn't hold
R/R wheel bearing
L/F wheel bearing
R/F Tie rod rack loose
Exhaust baffle broke inside muffler
Given these comments and the fact that the car sees a kot of dirt roads what should be repaired vs replaced vs upgraded. I seen some post of what manufacturers to stay away from in front end suspension but nothing on a common opinion of what should go in.
I want to get to drive it again and I'm not against throwing money at it. I've usually done the work on it myself given not a lot of shops want to work on Fieros. The clutch replacement was fun and I can never seem to get the ebrake right. Any feedback appreciated.
Notorio
Report this Post06-16-2020 11:54 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
R/R wheel bearing
L/F wheel bearing
The inspection is much more involved than in California where they seem to only be concerned with emissions.
qwikgta
Total ratings: 84
Report this Post06-17-2020 08:41 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless i'm missing something, you have a list of things to fix, if you want to drive it again. Here is the list of things that needs to be replaced.
E brake
R/R wheel bearing
L/F wheel bearing
R/F Tie rod
New muffler
Once those things are replaced with new parts, the state will allow you do drive it on the public roads so you don't kill someone.
Its called maintenance and in some states it would never get done unless the state holds it hostage.
Enjoy
RWDPLZ
Total ratings: 305
Report this Post06-17-2020 08:58 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are all pretty cheap/easy fixes.
Can also confirm California just cares about the engine looks stock and passes emissions, my Federal emissions 84 SE passed no problem with a newer non-California catalytic converter.
MacDee
Report this Post06-17-2020 09:45 AM Click Here to See the Profile for MacDeeSend a Private Message to MacDeeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I'm just wondering if this would be a good time to upgrade some items and where people are getting those upgrade parts usually.
Report this Post06-17-2020 03:01 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Upgrades" of most listed will fail too.
Rear brakes has problem and first thing to fix because cost can make you choice to fix others.
start @ https://www.fiero.nl/forum/F.../HTML/143946.html#p4
Replace wheel bearings and See my Cave, Front Bearings
Need 2 inner, 2 outer, and 2 seals to do both sides.
But now is time to get new hubrotors and pads if they are iffy too. Don't put new bearing in iffy rotors.
Get Wheel Bearing Grease for Disk Brakes! This grease handle the heat from brakes and won't run like many others.
Note Fiero and many others front wheel bearing are made to have a little play but many over tighten or leave too loose. You might only need proper adjustment but nube often have no clue what to look for before trying. Meaning bearing(s) can have real problems but can't see easy often even w/ old grease cleaned off them. So adjustment may seem to work but bad bearing will fry and leave you stranded at best.
Outer tie rod end is easy... inner not so much...
Can replace either/both but Carefully measure length first from the rack you can mark or otherwise find the point again to ball stud center. So alignment is close to drive to alignment shop.
If right side... measure from stud on moving end for stabilizer to outer end stud.
FieroMontreal
Report this Post06-17-2020 03:10 PM Click Here to See the Profile for FieroMontrealSend a Private Message to FieroMontrealEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's really not that bad.. I mean it's a lot but nothing you can't knock off by yourself. The E-brake will be the most annoying thing there IMO. If your handy you and the car isn't too rusty you can have all that done in a (long) day working in your driveway.
Does walker still make the V6 Muffler? I know the 4CYL one was getting scarce when I ordered mine a few years ago.
Report this Post06-19-2020 10:00 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Driveway repair? That's depends on just where you live. Example: Many HOA's, Counties and Cities can ticket or tow a disable car in hours to a few days. That's including parked in private driveways, on grass or other non pavement areas. Condo's and related are often worse and won't allow you working on a car at anytime.
FieroMontreal
Report this Post06-19-2020 10:36 AM Click Here to See the Profile for FieroMontrealSend a Private Message to FieroMontrealEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
[QUOTE]Originally posted by FieroMontreal:
Driveway repair? That's depends on just where you live. Example: Many HOA's, Counties and Cities can ticket or tow a disable car in hours to a few days. That's including parked in private driveways, on grass or other non pavement areas. Condo's and related are often worse and won't allow you working on a car at anytime.[/QUOTE]
I assume he is smart enough to figure out his limitations and what his situational factors are in order to make an informed decision. I'm not going to factor in everyone's personal environmental limitations, ask them about their living conditions and if they live in a HOA before suggesting that they can fix their own car at home like most of this forum does to begin with. I was simply trying to tell him that all of these repairs could be done at home, with rather simple tools and don't require a terrible amount of effort to fix. If he wishes to go to a shop that's up to him or her.
JohnyWalter
Report this Post07-31-2020 07:59 AM Click Here to See the Profile for JohnyWalterSend a Private Message to JohnyWalterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello!
The worst experience could be the time when your vehicle stop working even after repairing. In the best condition vehicle continues to work with a slight increment in its speed. If you are looking for an auto collision center, then you can contact no collision for further details. To avoid all these things suggest you read a decent article here Autokwix
[This message has been edited by JohnyWalter (edited 08-03-2020).]
