  Headlight door adjustment
Headlight door adjustment by earlpote
Started on: 05-05-2020 10:22 AM
Replies: 1 (344 views)
Last post by: Mike in Sydney on 05-05-2020 08:47 PM
earlpote
Report this Post05-05-2020 10:22 AM Click Here to See the Profile for earlpoteSend a Private Message to earlpoteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all,
Looking for advice/guidance on adjusting the pop up headlight door. Somehow mine came out of adjustment and screwed up the paint where they started touching 🤦‍♂️ Do i do this by loosening the two 10mm bolts on the underside? I tried screwing with this but it didnt give me much play, but i also didnt try to force it.
[This message has been edited by earlpote (edited 05-05-2020).]
Mike in Sydney
Report this Post05-05-2020 08:47 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Loosen the two, 10-mm screws to adjust the gap. You may need to use a rat-tailed file to get additional clearance for adjustment. I found that if you use cardboard or Popsicle sticks you can adjust the gap all around before you tighten the bolts. I also used blue Loctite (medium strength) to keep the screws from loosening but that was probably overkill.
Mike in Sydney
