Another that can't follow directions to properly use bushing press kit and other problems.
Can't even bother to a search here YT Google etc for how to use press kit w/o damaging the arms or even lube the screw.
HEI
Can run many Platinum etc plugs but like many other hates many Gimmick plugs. DIS hates more types like many Platinum etc w/ tiny centers as Bosch uses.
AC, Autolite and other make good Platinum and other plugs for both ignition types. Side effect is many of them has better shells that won't rust out fast.
Another that buys TFS hype. Hope he
Doesn't buy their fake brake upgrade parts too.
Sucks that someone sold a crap gas tank but bad rusty tank isn't he's TBI problem.
Very likely TBI has a iffy injector seal(s) or worse making even the New injector to drip gas. Leaking at the injector or leak gas just flows to low spot then drips. Either is likely to get worse.
If the TBI doesn't have problems might get away w/ a rebuild kit w/ all seals etc.
Note that This type of Fuel filter will handle a lot of crap. Isn't like small filters or worse very small filters in many Carbs. Many think crap stops by filter media along but heavy crap sinks and light crap float in the can.
Why? Can acts like wide river and slows speed of flow in the can.
Even if tank was clean, lines etc can hold a lot of crap that soon get lose and push to the filters.
Main filter get most crap then filter screens on injector get the rest of crap that could plug it. A lot get to injector screens then washers off by gas gets push thru the regulator to the tank again.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 01-04-2020).]
