  f40 trans
f40 trans by madbrad01
Started on: 12-18-2019 09:25 AM
Replies: 6 (308 views)
Last post by: madbrad01 on 12-19-2019 03:48 PM
madbrad01
Report this Post12-18-2019 09:25 AM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Talking about road racing with a buddy, and i was thinking i need a manual gear box.Well i did some searching on the f40 and the price for some parts are getting up there.So my question is whats the norm for a swap?
Report this Post12-18-2019 01:56 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the price for the F40s going up and since you basically have to replace or modify everything... $2,500 to $4,500 is the normal range depending on engine used, what parts you make vs. buy, and how much you spend on the clutch.
Import a transmission from Europe to do a final drive swap and you can add another $1,500 to $2,500 to that as well.
madbrad01
Report this Post12-18-2019 05:35 PM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! I my as well do a vette.
Report this Post12-18-2019 07:53 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is a great transmission, but when you have to literally change everything to install it, cost will always be an issue.
Having done the swap and the final drive swap, I would do it again and again. No regrets here, I love it!
Spadesluck
Report this Post12-19-2019 01:47 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
The F23 is always an option as well. Not a 6 speed but stronger than the stock piece. It is another tried and true transmission.
wftb
Report this Post12-19-2019 07:40 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the F23 is a lot cheaper and it uses stock Fiero manual trans axles available eveywhere. Lots of threads about it here on Pennocks.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
madbrad01
Report this Post12-19-2019 03:48 PM Click Here to See the Profile for madbrad01Send a Private Message to madbrad01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info, I think i'm going to stick with the auto.
