  Lost Fiero Indy possibly found (Page 2)
Lost Fiero Indy possibly found by Skatulaki
Started on: 11-05-2019 10:36 AM
Replies: 51 (1604 views)
Last post by: Skatulaki on 05-23-2020 12:35 AM
ltlfrari
Total ratings: 127
Report this Post12-14-2019 09:36 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you sorted the title issue out at all?. Getting the title sorted would be my first stop before I put anything into that car although it looks like a good project and worth saving if you do.
Dave
www.ltlfrari.com
Skatulaki
Report this Post12-30-2019 04:20 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
No Dave I have not, I have a couple things I have to do before I do that, I'm not buying anything for it yet anyway, all I'm putting into it right now is stripping it down, and deciding where I want to go with it.
Skatulaki
Report this Post12-30-2019 05:00 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skatulaki
Member since Nov 2019
OK , I got it into the shop, and began stripping it down. Man this car is dirty, making a mess in my shop, lol, I thought I cleaned the front out pretty good the other day LOL!
Right full of dirt, leaves, sticks, ants, lizards, and who knows what other critters!
I thought the radiator was broken at the bottom, and when I got the cap off I didn't see any but some, fluid spilled on removal. So even though the aluminum part of the rad frame
was broken at the bottom the vanes were apparently not leaking. The fluid looked very good so thats a good sign.
It definitely took an impact of some sort but not apparently a serious one as so far the only damaged parts, appear to be the lower radiator frame, ( excuse my lack of
knowledge on nomenclature on the parts) , the rubber splash piece and metal piece that that hold it to the bottom of the radiator frame.
The radiator bent but not leaking, shroud and fan missing, the a/c radiator also bent, not known if leaking or not but probably R=22 and an upgrade would probably be a good idea. Will need side lights, turn signal lights. Possibly needs front fenders and fascia ( not determined yet )
Still need to clean more dirt and leaves, but so far the Space Frame seems in really good shape, some but not much rust. A couple pics!
Skatulaki
Report this Post12-30-2019 05:19 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skatulaki
Been working on getting the passenger seat out and its been a real chore ! I can say right now, this car is gonna be go Big or Go Home ! At least labor wise !
I got the 2 front nuts out without much trouble, and the door side rear one with some difficulty, and a u joint extension and hammer to get it seated. The inside rear, I couldn't see or find and the slide rails were rusted and no amount of WD-40 seemed to help, even though it did free the latch.
So I had to get creative. So I think about it for a while and hmm. I drilled a hole in the front of the slide, screwed in a wood screw ( so the screw would break before bending slide ). Got a screwdriver hand hammer and started pounding. Looked like it was moving bit not sure. Got a BFH and 3 screws breaking later, got it where I think I can get a wrench on it.
Going back to work on it. Be back later tonight.
Skatulaki
Report this Post12-30-2019 10:19 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skatulaki
Got the passenger seat out but the Drivers seat is proving to be more demanding! urg
Found Boomerang CD whoever they are !
Pic of radiator
Skatulaki
Report this Post12-30-2019 10:21 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skatulaki
pic of radiator
? wont let me upload that one, no biggie
Skatulaki
Report this Post12-31-2019 10:26 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pics were not that big or blurry when I first uploaded them! Hmm
longjonsilver
Report this Post01-01-2020 10:54 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i would soak all bolts in penetrating oil for days before trying to take them out.
jn
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
Skatulaki
Report this Post01-04-2020 09:21 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been working on it some this week due to unexpected time off. I made a lot of progress. Got much of the interior out, got the carpet out of the trunk out. was disappointed to find out the car has also taken a hit in the rear and that the middle of the trunk is crinkled up. This explains the black Rear Fascia and maybe GT Deck as well. A previous owner banged the car up, and just fixed it with what was available cheap is my guess.
So far this car is a mixed bag of stuff either very well standing the test of time, or just not having done so at all. The weather striping is in excellent shape. Much looks very good condition. Some not that good.
Photo's in next Post.
Skatulaki
Report this Post01-04-2020 09:37 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skatulaki
Rear Trunk krinkled up and pushed too close to Muffler which cooked some paint off.
Rear Fascia, and Taillights Removed
Back Side of Rear Trunk Carpet
Front Side of Rear Trunk carpet broomed off
Skatulaki
Report this Post01-04-2020 09:45 PM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skatulaki
View of Rear trunk from other side.
Radiator I thought Broken but apparently not
Both seats out, have removed some more interior since then
Skatulaki
Report this Post05-23-2020 12:35 AM Click Here to See the Profile for SkatulakiSend a Private Message to SkatulakiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Back ! The year didn't start out well for me, and from the looks, it hasn't gone well for about 40 million others this year. At least I'm still working which I am gratefull for! I have spent most of the spring working on shop improvement instead of the Fiero. It cost me $150 dollars to just paint 2 bays concrete floor, so I decided I needed a better plan. I work for a road striping company so I asked the boss if I could have some of the empty paint barrels, he said take all you want. So I began taking the newly empty white ones with some sludge at the bottom, and I would paint a few square feet from each barrel, I painted the whole outside slab, and am half done with 3rd bay inside. problem is white shows all the dirt and stains easy. However it is highway paint and is not going to come up, so at least I have a good primer coat down, and saved my self at least $450.
I'm getting the urge though, soon I will be back to work on the Fiero, as well as my Dale Monte !
