| quote | Originally posted by KissMySSFiero: I’m looking to buy a mill/lathe combo.
I'd suspect that a combo machine would be neither a good mill nor a good lathe. Just a suspicion though, as I've never used a combo unit.
| quote | Originally posted by KissMySSFiero: What are some things to look for on a used machine?
The machine itself should have no missing pieces.
Then, look for the tooling (cutting tools, chucks, measuring instruments, vise, etc) that comes with it. The more stuff that's included, the less you need to buy before making chips for a project.
| quote | Originally posted by KissMySSFiero: Is it safe to assume a metal lathe can cut wood or plastic?
Plastic yes, I've done PVC, acetal, for sure some PE/PP on a metal lathe.
I made a wood paper-towel holder using a metal lathe, and the initial result wasn't so good. There was a lot of splintering. Probably some of that was due to not knowing how to cut tools for wood. I also think that typical wood-turning RPMs are higher than metal-turning RPMs. I ended up having to do a lot of sanding to get the paper towel holder OK.
