  Amazing finale race!
Amazing finale race! by lou_dias
Started on: 10-13-2019 06:35 PM
Replies: 5 (318 views)
Last post by: lou_dias on 10-22-2019 10:32 AM
lou_dias
Total ratings: 67
Report this Post10-13-2019 06:35 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just amazing driving by the Johnson brothers in the finale!
My wheel bearing gets the best of me again in turn 3-4. My race starts at ~11:15 mark.
Total ratings: 458
Report this Post10-13-2019 07:29 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
For sure... that was great!
Had to chuckle at... "Hello darkness my old friend, I've come to talk with you again."
[This message has been edited by Patrick (edited 10-14-2019).]
lou_dias
Total ratings: 67
Report this Post10-14-2019 12:32 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah - Al's had a bad season.
So have I. My rebuilt wheel bearing didn't even last thru me spinning the tires pulling onto the track to line up for my race. Hence my turn 3/4 spinout and poor launch.
That's why I'm looking to upgrade to the larger FWD bearing design...
da.slyboy
Report this Post10-16-2019 09:53 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I have never owned a heavily modified or high hp Fiero, but I would like some more info on why the wheel bearing failure. I just don't seem to hear/read about this often. Tire two wide causing it to be overhang from the center to far?? Does it just lock up the wheel?
lou_dias
Total ratings: 67
Report this Post10-22-2019 10:19 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think it's more of a factor of the weight of my wheels and the extreme G's I'm hitting. When one goes, you can see me launch only as good as a RWD because my wheel will wobble and you'll see it reflected in my front end how it looks like it's bouncing up and down because the rear wheel makes contact then loses some contact back and forth. My wheels are 315/35-R17's....and weigh 52 lbs each with the tires.
On a good launch, my front end will rise then come down only once until I shift into second gear.
lou_dias
Total ratings: 67
Report this Post10-22-2019 10:32 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
If you watch this event, my first 2 launches were great!
Next two I had some bounce because my bearing was going bad.
By the 5th launch, the extra vibration lead to a snapped CV...
