  Tail light diameter
Tail light diameter by LornesGT
Started on: 12-26-2018 12:09 AM
Replies: 9 (422 views)
Last post by: LornesGT on 01-04-2019 09:43 PM
LornesGT
Report this Post12-26-2018 12:09 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the diameter of the Ferrari looking tail lights some of you have used?
Thank in advance.
Lorne
hnthomps
Total ratings: 51
Report this Post01-01-2019 08:31 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you will accept measurements on a Mera tail light lens, I can give you ID and OD measurements.
Nelson
LornesGT
Report this Post01-01-2019 10:30 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, please do they look to have the right proportion. I have a grand idea of making my own but with a twist.
hnthomps
Total ratings: 51
Report this Post01-03-2019 02:15 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I measured the Mera tail light lens a few minutes ago and the dimensions are as follows:
OD - 6.08"
ID - 5.79"
These measurements were made at the base of the lens and were above the next step ledge. Based on visual inspection, the Mera lenses are very similar (and almost exactly the same size) to the F308/328 lenses. Mu guess is that there is less than 0.1" difference but I have never measured a F car tail light lens.
Nelson
[This message has been edited by hnthomps (edited 01-04-2019).]
LornesGT
Report this Post01-03-2019 10:02 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you!
Report this Post01-04-2019 11:52 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
kinda odd that an inside diameter is larger than an outside diameter.....but it must be obvious to those who know the lens.
Rexgirl
Report this Post01-04-2019 04:20 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Simple explanation: clearly manufactured with the same technology as the TARDIS
Blacktree
Total ratings: 350
Report this Post01-04-2019 04:47 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL
hnthomps
Total ratings: 51
Report this Post01-04-2019 06:45 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, that just happens when you are in a hurry and do not check the typing. You can (and I did) reverse the ID and OD numbers. I will go back and edit them to the correct values.
Nelson
LornesGT
Report this Post01-04-2019 09:43 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I notice that as well but figured you meant the inner light assembly was a different diameter than the outer light assembly.
