Click here to visit the donation page | View all sponsors
  3.4L Headers?
3.4L Headers? by heypal
Started on: 11-30-2018 09:38 AM
Replies: 4 (292 views)
Last post by: pmbrunelle on 12-18-2018 06:44 PM
heypal
Report this Post11-30-2018 09:38 AM Click Here to See the Profile for heypalClick Here to Email heypalSend a Private Message to heypalEdit/Delete MessageReply w/QuoteDirect Link to This Post
This morning I Googled "3.4L Headers". Sure enough a couple options popped up. Is there any merit to using them in a 3.4 swap? They have to flow better than the lousy stock manifolds.
Spadesluck
Report this Post11-30-2018 09:42 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Headers you really cannot lose out. However depending on what's done to the car is how much you may benefit from them. I am sure you can find 3.4 headers but finding a set to fit in the fiero could be a bit challenging. The stockers ported out are not all that terrible. If I was going to change anything it would be the ypipe that connects the headers together.
[This message has been edited by Spadesluck (edited 11-30-2018).]
Total ratings: 313
Report this Post12-07-2018 11:49 AM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the sprints were discontinued the only headers available are for the S10 . They won't fit a Fiero install without serious modifications. I have a new S10 set but they won't fit without serious modifications.
[This message has been edited by Dennis LaGrua (edited 12-17-2018).]
Blacktree
Total ratings: 342
Report this Post12-16-2018 05:07 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageClick Here to Email BlacktreeSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Porting the stock manifolds and Y-pipe helps, but headers are even better. It's been proven that porting the stock exhaust yields 8-10 HP. And my dyno test of the Trueleo headers yielded 7 HP more than a ported exhaust. So a good set of headers should yield about 15 HP over stock.
As for sources... good luck. Headers used to be available from the Fiero Store and Trueleo, but not any more. I'm hesitant to recommend WCF, because of their shaky reputation.
Edit to add: Keep in mind the Camaro / S10 headers are for a longitudinal setup. And the Fiero has a transverse setup. The S10 headers will probably interfere with the Fiero transaxle, plus the exit will be in the driver side wheel well. In other words, you'll need to make some serious modifications to make those headers work.
[This message has been edited by Blacktree (edited 12-16-2018).]
pmbrunelle
Total ratings: 53
Report this Post12-18-2018 06:44 PM Click Here to See the Profile for pmbrunelleClick Here to Email pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's your budget? What are your shop skills like?
That might rapidly narrow down the choices.
[This message has been edited by pmbrunelle (edited 12-18-2018).]
