  84 Iron Duke fit in an 89 s-10?
84 Iron Duke fit in an 89 s-10? by BadNewsBrendan
Started on: 10-23-2018 12:28 PM
Replies: 3 (143 views)
Last post by: BadNewsBrendan on 10-23-2018 04:23 PM
BadNewsBrendan
Report this Post10-23-2018 12:28 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Selling my Iron Duke from an 84 and a guy asked if it is a direct fit into an 89 s-10, I am pretty sure it is the same engine but can anyone confirm this? Not sure if anyone knows much about s-10s on here but I would appreciate any help. Thanks
BadNewsBrendan
Report this Post10-23-2018 12:43 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
And by fit I'm guessing he wants to know if it has same mounts, sensors, coolant inlets outlets etc so he can just throw it in without any modification.
Report this Post10-23-2018 04:10 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
Is similar job as using a V6 in 84. IOW this swap is a big job to a very big job and have to rewire everything to the engine and ECM for 84 because 87 and up L4 are very different engines and use different ECM. Plus many other things will need to be mod'ed or replaced because 84 was made only for the 84-86 engine. Even using 85-86 L4 engine has changes and needs some work to fit 84.
And doesn't add much power for the effort and money spend.
More See my Cave, Duke Quick Ref
Then add truck is likely VIN A or E engine and many won't fit 87+ VIN R engine water pump parts and starter holes on wrong side at minimum.
BadNewsBrendan
Report this Post10-23-2018 04:23 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay that sucks, don't want to sell somebody something they don't need. Thanks a lot for the info! (PS it looks like your site has a ton of good info but for some reason all the links on the left are overlapping the text and I can't read half of it.)
