  Corvette swap hubs
Corvette swap hubs by Spiders1
Started on: 10-01-2018 11:28 AM
Replies: 3 (333 views)
Last post by: Spiders1 on 10-01-2018 10:52 PM
Spiders1
Report this Post10-01-2018 11:28 AM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone making the swap hubs? Or know of anyone still making them?
86 GT 3.8 Twin-charged 5 speed FWD Getrag 3.92 gear swap
91 GMC Syclone 20k original miles
cvxjet
Report this Post10-01-2018 11:50 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought some aluminum hubs from Sluppy123......That was about 2-3 years ago.....Don't know if he is still making them. Also makes brackets to adapt 88 calipers to early spindles. I drive hard on bad roads and everything has held up......
Send Sluppy123 a private message or Email and see if he is still making them....
sluppy123
Report this Post10-01-2018 02:55 PM Click Here to See the Profile for sluppy123Send a Private Message to sluppy123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a few 7075 Aluminum hubs on hand that will work with all Corvette swaps. 5x100 bolt pattern, the Corvette rotor centering ring is turned onto the hub. 50 mm long wheel studs and timken races are pressed. I also include timken bearings and races. $350 shipped.
Spiders1
Report this Post10-01-2018 10:52 PM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the responses.
I got some from you sluppy 4 years ago but they disappeared.
I also sent you a message a few days ago asking if you still made them.
I can’t remember if the last ones were aluminum but I think they significantly less.
Do you still make regular ones?
