  New oil??
New oil?? by kgoodyear
Started on: 06-10-2018 11:29 AM
Replies: 4 (285 views)
Last post by: Dennis LaGrua on 06-14-2018 04:50 PM
kgoodyear
Report this Post06-10-2018 11:29 AM Click Here to See the Profile for kgoodyearSend a Private Message to kgoodyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a minor problem with my oil pan and had to replace it. I have NAPA's purple oil and their best quality filter in it and it probably only has a dozen or so hours on it. I saved it in a clean container and was intending to put it back in and top it off with more of the same oil. I was going to put in 5 quarts total.
Do you think it is alright to use this "nearly new" oil?
GM 3800SC 1999
Goody
The beauty of a solution lies in its simplicity
[This message has been edited by kgoodyear (edited 06-10-2018).]
JohnWPB
Total ratings: 144
Report this Post06-10-2018 11:45 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should be no problem at all. As long as the container, as you said it was, was clean. As a further measure, you can use a paint funnel / strainer to pour it through to make sure there are no contaminates in it. Even without it, as you said the container was clean so it should be no problem.
[This message has been edited by JohnWPB (edited 06-10-2018).]
kgoodyear
Report this Post06-10-2018 11:49 AM Click Here to See the Profile for kgoodyearSend a Private Message to kgoodyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
cool! That oil was pretty expensive.
Goody
Red98422
Report this Post06-11-2018 10:52 PM Click Here to See the Profile for Red98422Send a Private Message to Red98422Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1 on the paint strainer. You should be fine to re-use it
Total ratings: 328
Report this Post06-14-2018 04:50 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Provided it is not old oil that sat (like in the crankcase for two years) ; if you have a dozen hours of use on that oil, it should be perfectly fine to be re-used.
