  Fabbed intake found.
Fabbed intake found. by sourmash
Started on: 06-01-2018 08:52 PM
Replies: 3 (326 views)
Last post by: pmbrunelle on 06-02-2018 12:10 AM
sourmash
Total ratings: 50
Report this Post06-01-2018 08:52 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
This was found in a junkyard. Was this a common modification to get around the choke point in the stock intake neck?
fierosound
Total ratings: 286
Report this Post06-01-2018 09:30 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think that's a "one off" mod by someone to do what you are suggesting.
The distributor would likely interfere with the TB in that position.
sourmash
Total ratings: 50
Report this Post06-01-2018 09:45 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right. You're probably right. The car was converted to turbo and had coil packs. Hmm. Wonder where the trigger is. Didn't think of to look.
[This message has been edited by sourmash (edited 06-01-2018).]
pmbrunelle
Total ratings: 62
Report this Post06-02-2018 12:10 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The successors of the 2.8 have crankshaft triggers. In the middle of the crankshaft is a notched wheel. Penetrating the right side of the engine block is a variable reluctance sensor.
These VR sensors would typically interface with the coil-pack module; this presented an "emulated distributor" to the ECU, which I guess eased GM's transition from distributors to coil packs.
There's a good chance your junkyard car had one of these setups.
Eventually, GM outgrew the "emulated distributor" paradigm, and the crankshaft sensor was wired directly to the ECU.
