18 by TOMZILLA
Started on: 05-01-2018 07:43 AM
Replies: 5 (348 views)
Last post by: olejoedad on 05-01-2018 11:44 PM
TOMZILLA
Report this Post05-01-2018 07:43 AM Click Here to See the Profile for TOMZILLASend a Private Message to TOMZILLAEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can anyone confirm if 18x7.5 wheel with a +45 offset will fit front and rear on an 88 GT? If so what would be a good tire size? 215 40 18 ?
[This message has been edited by TOMZILLA (edited 05-01-2018).]
Spadesluck
Report this Post05-01-2018 12:46 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you done a search for the tire guide? It will give you an idea of all the offests for your car.
Here is what a quick search pulled up Offest Chart
Report this Post05-01-2018 06:00 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should be ok on the rear. You can go up on section width on the tire on the rear with no issues.
There is room for a lot of tire on the rear of an 88.
TOMZILLA
Report this Post05-01-2018 08:31 PM Click Here to See the Profile for TOMZILLASend a Private Message to TOMZILLAEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I'm looking at 245/40/18 for the rear and 215/4018 for the front sound about right? Or would 225/40/18 work better on the front? For wheel size I'm looking at 18 with either a +40 or +45 offset. I don't want the tires sticking out from the fenders. So would the +45 tuck them in more?
Total ratings: 463
Report this Post05-01-2018 10:06 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
+45 will tuck them in more.
I run 17x8s with a 35 offset on the rear of my 88. (235/45)
17x7 with 48 offset on the front. (215/45)
The rears tend to stick out, jsut a smidge, but I like it that way.
Here's a sort-of closeup of the rear.
Report this Post05-01-2018 11:44 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rears stick out a bit on the 88 with the stock lace wheels.
To the OP, why not go up to a 45 aspect ratio? They will look better, ride a bit better and fill the wheel wells better.
