  Code 34 and 44?
Code 34 and 44? by copperhens
Started on: 04-30-2018 08:04 PM
Replies: 3 (129 views)
Last post by: Gall757 on 05-02-2018 09:02 AM
copperhens
Report this Post04-30-2018 08:04 PM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
The daily started acting up today. Sounds restricted when I rev it. Doesn’t shift correctly, goes up to 5k Rome and only shifted when I let go of the gas. Replaced map and mat sensors. Still am getting codes 34 and 44. Also runs hot.
‘87 V6 auto
Report this Post05-01-2018 01:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Because O2 sensors are cheap and easy to replace I would start there. As for running hot....Fieros run hot. Does your fan run while the car is moving?
copperhens
Report this Post05-02-2018 07:02 AM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, my O2 sensor is cracked anyway. I am gonna chop off the cat.
The Fiero runs really hot though. It used to run at 150F driving around, now not even started for 5 minutes it’s at 250F.
My fan runs when I have the vents on, otherwise no, I need a new relay.
Report this Post05-02-2018 09:02 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
150 F is a cold engine that uses extra fuel. Minimum normal operating temperature is around 170 F and your thermostat should be 195 F. You will get false readings after the engine is turned off because there is no coolant circulating.
The fan is supposed to run when you have the A/C on..
[This message has been edited by Gall757 (edited 05-02-2018).]
