  Door lock
Door lock by FX
Started on: 04-29-2018 03:54 PM
Replies: 3 (164 views)
Last post by: FX on 04-30-2018 07:44 AM
FX
Report this Post04-29-2018 03:54 PM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys, I have to replace the driver door lock in my '86 GT. Does the power window mech have to come out, and what should I expect? Previous owner still can't find the service manual.
fierofrenzy
Report this Post04-29-2018 06:30 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi FX , Since nobody has yet responded to your question, I at least can tell you this. To the best of my knowledge, the power window mechanism is completely separate from the door lock and assembly. I was in there more than once doing dew wipe replacements. Its easy to pull the inner panel to see what your up against, you just may have a tight squeeze being its position in the upper edge of the door. good luck.
CoolBlue87GT
Total ratings: 151
Report this Post04-29-2018 10:56 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try this link, http://www.ltlfrari.com/ select door locks.
Hope it helps, good luck.
[This message has been edited by CoolBlue87GT (edited 04-29-2018).]
FX
Report this Post04-30-2018 07:44 AM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
I should have said outer lock, but this link has it all, I'll save it. Thanks guys...
