  88 Rear brake "T" valve
88 Rear brake "T" valve by 06GTO
Started on: 03-30-2018 02:12 PM
Replies: 4 (201 views)
Last post by: Patrick on 03-30-2018 04:47 PM
06GTO
Report this Post03-30-2018 02:12 PM Click Here to See the Profile for 06GTOSend a Private Message to 06GTOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems like spring has finally arrived and redoing the brake lines on my 88 coupe build.
Looking for a new "T" valve for the rear brakes (located on the passenger side). Anyone know the name and/or part number of this thing? Pretty rough looking and I'd like to replace it, but I'm not even sure what it's called.
Report this Post03-30-2018 02:27 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's just a junction block, used on all Fieros.
steve308
Total ratings: 58
Report this Post03-30-2018 02:51 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Brake proportioning valve located near the master cylinder? or something else?
[This message has been edited by steve308 (edited 03-30-2018).]
06GTO
Report this Post03-30-2018 04:00 PM Click Here to See the Profile for 06GTOSend a Private Message to 06GTOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any idea on where to get a new one? Part Number?
Total ratings: 463
Report this Post03-30-2018 04:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 06GTO:
Looking for a new "T" valve for the rear brakes (located on the passenger side). Pretty rough looking and I'd like to replace it...
I know the "T" you're referring to, hidden away in the passenger side rear wheel well. As previously posted, it's not a valve, it's just a junction.
I forget, isn't it made of brass? If so, it won't be corroded... just dirty. I'd be more concerned about the brake lines that are attached to it.
