So three days ago I brought my 88 GT in to my local mechanic to have him install my exhaust. The car came with a brand new GM OEM cat back exhaust and the old exhaust wasn't even in the car anymore so all they had to do was hang it and weld it in. That was three days ago. I've called nightly to find out what was the status and I keep being told they got busy, haven't gotten to it yet etc. Finally this morning they call me.
Seems that last night they pulled my car in and got started but closed before they were finished. This morning they finished up and backed my car out. They claim that they put it in first and the car just won't move. They put it in every gear and it just sits there. They tell me they can see the clutch master cylinder moving and the "feel" it going into gear but it just won't move. They offer no apology, nor any offer to figure out what happened. Just come get it as it is. After pleading they guy agrees to tow it home for $20 but that doesn't seem right, since it broke in their possession, the very least they could do was tow it for free. I should mention that I live 1.5 miles away. I have to demand to talk to the owner who I've known passingly for 20 years and once I get him on the phone he agrees to tow it home free. No offer to look at it at all. Oh, and he says I have to pay cash. Feels ultra shady, like they are trying to get away with something. I'm stuck here at work until about 2:30 then I'm heading down there. I'm planning to pay with a credit card just so I have some record of my payment and I'm going to make they write on the receipt that they delivered my car broken.
I think it would be really hard for them to have broken it so thoroughly, unless they took it out and beat on it. Did you record the mileage when it was dropped off?
No, you're the second person who asked me that Now I really wish I had. The guy that worked on the car told me he used to have one and he was really excited to work on it. That plus them trying to get me to pay cash makes me wonder if he joyrided it and broke it. I didn't mention that the trans and clutch were perfect prior to me bringing it in. No slipping and shifted clean. How the hell would it have broken on the rack?
I've never seen a Getrag blown so thoroughly that the car wouldn't move, without anything showing, outwardly. I shattered the differential on mine, and was still able to drive it home.
First, try to get them to make it right, it seems you've already done it. Document everthing and take it to a trans shop to get it checked out. If you drove it in and it is a major internal problem, not just a broken cable or some other "consumable", I'd try to reason with them again. They know you drove it in and it didn't drive out, it would be hard for them to argue they weren't at fault.
We need more information. How long have you owned this car? Have they worked on your Fiero before? There are fewer and fewer mechanics that know how to fix a Fiero....In a normal repair relationship, they should keep the car and at least give you a quote on what is wrong and how much to fix it. It sounds like they don't want to touch it....(which is not unusual).
[This message has been edited by Gall757 (edited 03-02-2018).]
It's possible they want you to pay with cash because there's no way for you to contest it and get it back. I think I would call the police in to make a report on it, then pursue action through Magistrate's Court.
I've had the car for about 6 months now? I haven't been driving it much because it needed a few small things first, new EGR tube, Rodney's select cable and exhaust. I drove it 2 hours home and have taken it for several short drives but it has shown nothing to make me think it's going. It will occasionally grind a tad in third but the clutch grabs solid and it shifts really clean. I just got home, I paid with a credit card when nobody was paying attention They are towing it home now. I did get to jump in it and the clutch pressure feels normal but that's as far as I got.
Had similar issue with another shop. You are left with 2 options, find a new shop or persue action. I'd get a Transmissions shop opinion if its a fail part, i'd move on. If its something from abuse I'd go after them.
Ok, it's home and I got to check it out. I'm totally baffled. I think the clutch might be shot? So with the car running, I can shift through the gears without pressing the clutch down. The clutch pedal feels pretty normal, maybe a tad softer than usual. I can see the clutch cable moving at the master cylinder. Trans feels great, still shifts nice.
On a side note, the shop straight piped my catalytic converter. I did not ask them to. It's just as loud as it was with no exhaust.
How many miles are on the car? When was the clutch last replaced?
30 year old cars break, sometimes unexpectedly, without warning, and w/o abuse... so I would hold off accusing the shop of something until you figure out what is wrong.
If the shop truly didn't do anything to make it fail, you just lost a shop that is willing to work on your car.
The cash deal could be to avoid giving uncle sam 30% of it, it could also be about the straight-pipe mod and have nothing to do with the transmission issue.
Some possible causes: Pressure plate is bound up in the released position Center hub of clutch disk broke free or splines completely stripped off flywheel bolts sheared off crankshaft snapped at rear of crankshaft Shift forks broke with transmission in neutral etc...
Time to pull the transmission and figure out what is going on.
The master cylinder is in the front compartment. There are no cables related to the transmission that go anywhere near it. You might be referring to the slave cylinder?
There are no clutch cables in a Fiero. The system is fluid operated hydraulics.
Movement of the cables can only be seen when the shift surround is removed and you're peering down into the shift mechanism, or when viewing the cables where they attach to the shift levers on the transmission.
Now, with the engine turned off, have someone operate the clutch pedal while you observe the slave cylinder and it's pushrod to be sure the pushrod is moving.
Next, have them shift through the gears to be sure both your cables are operating the levers on the transmission. If they are operating, then you have a clutch or transmission problem.
If you didn't tell them to remove the catalytic converter, tell them to replace it or you'll report them to the authorities. Even though you might know these people, they don't seem to care about you, so I wouldn't play nice with them.
Not sure if this info helps or not, but when the factory clutch went out on my 88 gt it was instantaneous and with zero warning. One second it was holding great, and the next it couldn't even make the car roll forwards. And that was with only 28,000 miles.
Maybe they were hooning your car, maybe they weren't. Without mileage recordings or dash-cam footage I don't think there is a lot you can do.
At the recommendation of somebody else, I just went outside and manually put the car in second gear at the transmission. When I move the linkage it feels like it's going solidly into gear. I then was able to push the car like it's in neutral. This was with the car not running and the clutch not depressed.
There is a remote possibility that you have a broken axle stub, where it plugs into the differential. If that's the case, everything inside the trans will turn - including the differential - but the axles won't. If that's the case, you should be able to *gently* pry against the tulips (tripots) and the broken one will fall right out. Getting the broken stub out will be a lot of "fun". You'll have to remove the good axle, and the drive the stub out from the far side. Before you do any prying on the axles, make sure you have a pan under the differential housing. If / when the axle comes out, several pints of fluid will drain out, as well.
Or it still could be a broken clutch, as others have said. That still seems like the more likely scenario.
Edit - remove the bolts from the tin shield at the bottom of the clutch housing. pull it back out of the way. If the clutch is blown, there should be some pieces of clutch (hub or lining) in the bottom of the housing. Also... (thinking) if the axle is broken, you should see the speedometer register, with the engine running and the car in gear.
[This message has been edited by Raydar (edited 03-03-2018).]
No clutch fluid would allow the clutch to stay fully engaged all the time and he wouldn't be able to move it when it's in gear as he described. Starting it while in gear would make the car move.
Originally posted by fierofool: No clutch fluid would allow the clutch to stay fully engaged all the time and he wouldn't be able to move it when it's in gear as he described. Starting it while in gear would make the car move.
Oh yeah, your right.
Sounds like what Domtech posted, "when the factory clutch went out on my 88 gt it was instantaneous and with zero warning"
I suggest you start with the necessities. You're going to have to pull the transmission, one way or another. If it's the clutch assembly, then the money you've saved on a transmission could be put toward a 3.4 swap. If it's a transmission problem, and your engine is in good condition, stay with the 2.8. Even having said that, it all depends upon your budget and time.
Raydar may have hit it. I think if it were the clutch plate there would be a lot of noise. Drain and save the trans fluid and see if there's metal in it. If not, you can put it back in the trans. But again, it seems that dropping the cradle is a given.
If the speedo is registering, the differential is turning. I'm still betting on an axle broken, somewhere. With the engine running, and the car in gear, have someone look at the tripots, nearest the transmission. If one of them is turning, but the axle (or outer joint) isn't, you've found your broken axle. If neither of them is turning, the stub could still be broken on the inside of the trans. I'll refer you to my post above.
If it's just a broken axle, it can likely be replaced without dropping the cradle.
Good luck.
It would be hard to imagine that problem occurring with the car just being backed out of the shop....
I agree. But the problem is proving it. It's pretty obvious that the shop isn't going to "butch up" and admit to anything. At least, if it's just an axle, it can be repaired in a few hours, instead of dropping the whole cradle.
Ok, I think I'm screwed. This morning I jacked the back end up and started the car and put it in first gear. Neither wheel moved, even giving it some gas. If I spin the wheels manually i hear a loud clunk clunk clunk sound about every rotation or so.
I believe that what Raydar said is something you should check; With the trans in gear, and clutch out, engine running, you should check your speedo....If it is not moving, it's the clutch/upper transmission, if the speedo needle is moving up, then it may be your half shafts or differential.
If it's a half shaft, that is a much easier fix than trany or clutch....Check this out before doing anything else!
I had a somewhat similar situation; Took my car to be smog checked for re-registration, then drove to the store maybe one mile....Clutch started making horrid noises and smoking...Got it home and the TOB was absolutely toasted! Maybe 500-1000 miles on new clutch! (And I was extremely careful to lube everything up with proper grease!) Ram Clutch covered it so I just spent a bunch of fun time re-tearing the backend apart.
I did not go after the shop....Owner is my friend and a straight shooter, but he had hired a helper who tested my car that day...lesson learned; I only let the owner test my car now.
Did you try prying the axles out? If one of the stubs is broken off in the diff, it would allow the diff to turn (inside the trans) without either axle turning.
[This message has been edited by Raydar (edited 03-04-2018).]
Talked to the shop today, they'll install any cat I want free of charge. Still maintain they had absolutely no responsibility in the damage, refuses to even put it on a lift and look at it.
I agree with the axle diagnosis. And the chances of that happening without abuse slim to none. I would not take it back there. You can get that stub out and replace the axle.
Did you get a receipt? Seems like the shop would have some explaining to do removing a cat and installing a test pipe...
make sure they didn't crush your coolant tubes too.
I did get a receipt, and the cat removal is nowhere on it. They already agreed to put any cat I want on for free but I really don't want to go back there. I'm temped to just do a charge-back on my credit card.
I haven't gotten time to look at the axle yet, hopefully this weekend.
.... I'm temped to just do a charge-back on my credit card.
That shouldn't even be in question, should it? Best case scenario, they were not responsible but are refusing to practice good customer service and confirm it. Worst case, they abused your car.
