  spring pad / isolator / cover / ......
spring pad / isolator / cover / ...... by mmeyer86gt/gtp
Started on: 02-20-2018 11:04 PM
Replies: 4 (198 views)
Last post by: olejoedad on 02-22-2018 09:14 PM
mmeyer86gt/gtp
Total ratings: 73
Report this Post02-20-2018 11:04 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking for what people are using for a replacement for the spring pad in the front or the rear. i saw fiero store stocks something but was looking for a poly setup.
pmbrunelle
Total ratings: 63
Report this Post02-21-2018 07:58 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Polyurethane here is like polyurethane ball-joint boots... I don't see the benefit.
IMSA GT
Total ratings: 250
Report this Post02-21-2018 09:35 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
These should work fine for the front. I'm not sure which part number would fit the rear.
https://www.amazon.com/Ener...olator/dp/B000CN72II
[This message has been edited by IMSA GT (edited 02-21-2018).]
Report this Post02-22-2018 07:09 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just use some 1/2" heater hose and slide it over the ends of the spring.
Report this Post02-22-2018 09:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or if you want less 'cush', wrap the top of the spring with an old bicycle tube. The isolator/pad is only there to prevent metal to metal contact, reduce vibration and quiet the ride.
You'll also get a little bit of lowering as well.
