  GT wheels??
GT wheels?? by adm927
Started on: 02-07-2018 11:09 AM
Replies: 5 (321 views)
Last post by: jjd2296 on 02-08-2018 07:19 AM
adm927
Report this Post02-07-2018 11:09 AM Click Here to See the Profile for adm927Send a Private Message to adm927Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if there is a company out there that makes wheels that are nearly identical to the stock GT wheels, but in bigger sizes like 17 or 18”? I want to maintain the stock appearance but I plan to upgrade to larger brakes.
Report this Post02-07-2018 02:50 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try to find some from the Beretta GT. Go onto the Beretta forum, and if you can put up with them, ask if any are available.
Grand Ams also had a lace wheel style in a larger size. I believe the Beretta wheels were 17" I had a set of black lace 14 inch on my first 85GT and they were made by Enkei.
Dodge Caravans also had a similar wheel.
[This message has been edited by fierofool (edited 02-07-2018).]
Spadesluck
Report this Post02-07-2018 03:25 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Beretta GTZ rims are only 16" so I would think the GT rims would not be bigger than that. Any 16" or bigger rim should accommodate a bigger brake system just fine.
css9450
Total ratings: 86
Report this Post02-07-2018 03:46 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Indeed, Beretta GT wheels are 15".
Report this Post02-08-2018 01:06 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found a lot of OG (Original Goods) Sans cross lace style when doing an image search. Never heard of them.
Didn't the later year Berettas and Grand Ams have larger diameter wheels?
jjd2296
Report this Post02-08-2018 07:19 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can do the Lebaron rotor and s10 calipar brake upgrade and keep your stock rims. The only mod needed to accommodate the s10 calipars under the stock rims is a little grinding and smoothing of the calipar surface. You have to remove the 2 nubs on the top of the caliper. If you want pics on how to do it just pm me.
