  Need advice on fixing a sagging front fascia
Need advice on fixing a sagging front fascia by Quad Raider
Started on: 10-18-2017 10:26 PM
Replies: 11 (722 views)
Last post by: Australian on 10-30-2017 07:17 AM
Quad Raider
Report this Post10-18-2017 10:26 PM Click Here to See the Profile for Quad RaiderSend a Private Message to Quad RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The front fascia on my '87 coupe has a bad sag in the middle. It's where the metal bracket is supposed to attach the center of the fascia to the space frame. The bracket and the flange it's supposed to attach to were long gone when I got the car.
In this photo, the sagging part is where the clamps are attached.
I'm thinking about cutting some aluminum plate and using fiberglass to attach it to the inside of the fascia to straighten out the sag.
Report this Post10-18-2017 11:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the same nose as on my (and everyone else's) '88 Formula. I forget exactly what the factory bracket looks like that's missing on your car, but why not simply fabricate one up. It just needs some support in the middle. Or is that what you're doing?
cvxjet
Report this Post10-19-2017 12:01 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I converted my 85 SE V6 to a 87-88 base nose like that...I did not have the center bracket, so I took some aluminum flat stock (1/8" thick) and bent it so I could bolt it to the bumper and down at the center of the fascia....
Blacktree
Total ratings: 350
Report this Post10-19-2017 10:16 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ I like that idea.
The front impact beam has a flange that hangs from the bottom of it. You could make a couple brackets to connect your fascia to that.
cvxjet
Report this Post10-19-2017 11:35 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
The one I built went up inside the center piece...there was room for only one- but it is strong......I may try to get in there and take a pic- But I am not disassembling it.....
Quad Raider
Report this Post10-19-2017 01:38 PM Click Here to See the Profile for Quad RaiderSend a Private Message to Quad RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Quad Raider:
I should have specified. I've obtained two replacement brackets, one from a member here and one from a salvage yard car. The tab on the space frame is missing on my car, so I'll weld on a replacement.
The problem is, my fascia has sagged so much I don't think the bracket will be enough to straighten it out. The bend is worst right where the clamps are attached in my photo, so I need something solid to hold the material flat.
In the next few days I'll try to post a photo or two without the clamps so you can see the problem.
Quad Raider
Report this Post10-19-2017 01:49 PM Click Here to See the Profile for Quad RaiderSend a Private Message to Quad RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quad Raider
Member since Dec 2010
Turns out I took a photo of the salvage yard bracket before I removed it from the car.
[This message has been edited by Quad Raider (edited 10-20-2017).]
Report this Post10-19-2017 03:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have all the rest of the metalwork (associated with the air dam) to put back on the underside of the nose? If so, I think you'll find that installing that supportive center metal bracket will be more than enough to take the sag out of the nose. If you don't have that metalwork, you need it.
Tony Kania
Total ratings: 305
Report this Post10-19-2017 06:11 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I fixed my sagging in a different manner. I used the broken GT fascia and cut out a section of it slightly smaller than the entire width of the mouth opening. A strip of fascia. This section was bonded to the underside of the nose just below the license plate in the picture. I removed the center spire that the GT nose has in the middle which was the area where my plate is mounted. It sagged badly and bonding another piece of the nose to the underside helped a lot.
In the pic it looks slightly sagged, but it is not. It has been like this for five or so years.
Yes, the plate is readable from a Police cruiser. It has been tested, and Seattle approved.
I used NAPA Flex Bumper Repair Kit No. 765-1540. I let it harden to directions before use.
[This message has been edited by Tony Kania (edited 10-19-2017).]
Quad Raider
Report this Post10-20-2017 01:33 PM Click Here to See the Profile for Quad RaiderSend a Private Message to Quad RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to this car, I finally do have all of the hardware that was missing.
I don't think installing the missing bracket will fix the problem. My fascia has a 90-degree bend in it right where I've placed the clamps, almost like the car sat with the fascia squished against a wall or something. I'll post photos this weekend of what it looks like without the clamps.
Quad Raider
Report this Post10-22-2017 09:43 PM Click Here to See the Profile for Quad RaiderSend a Private Message to Quad RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally got some time with the car today. After sitting for a week with a piece of wood clamped to the sagging part, it looked much better.
I cut a piece of aluminum to attach to the top of the sag. Not sure how I'll attach it, fiberglass or panel cement.
As I mentioned, my car was missing the small bracket that holds the center of the fascia to the space frame. It's also missing the flange on the space frame to which the bracket attaches.
I think the previous owner either hit something with the car, or it was damaged when she had a friend tow it when it quit running a couple of months before I bought it.
Australian
Report this Post10-30-2017 07:17 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
