  New way to install tang band speaker into factory housing
New way to install tang band speaker into factory housing by jjd2296
Started on: 09-24-2017 08:59 PM
Replies: 5 (446 views)
Last post by: Australian on 10-06-2017 05:19 AM
jjd2296
Report this Post09-24-2017 08:59 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Read a few posts here about installing the tang band speaker into the factory sub box which required removing the original mounting hardware and making a insert out of mdf to mount the speaker to. I figured that since the grill wouldn't be reused with the install of the tang band speaker that I would try and see if I could cut the grill out and expand the opening to fit the speaker. I used my dremel tool took about a half hour but it worked. I then drilleed some pilot holes for the 4 screw holes on the speaker. I mounted the cover first then inserted the speaker and secured it with 4 self taping screws. The speaker comes with some foam on the backside to make a table get seal so I didn't have to use anything else. It worked perfectly !!20 times better sound very nice deep bass for such a small speaker !! Much faster install then cutting mdf!!
jjd2296
Report this Post09-25-2017 06:54 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a pic of the finished product. Don't mind the brown screws I used them as they were the perfect length and had a larger head on them and were self tapping aluminum siding screws. Worked perfect
Report this Post09-26-2017 04:28 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good!
I ended up making a sheet metal end cap for mine... a lot more work.
jjd2296
Report this Post09-27-2017 06:12 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow that is a lot of work!!
Frizlefrak
Total ratings: 72
Report this Post10-01-2017 04:55 PM Click Here to See the Profile for FrizlefrakSend a Private Message to FrizlefrakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!!
Tempted to pull my TB sub out and rework it now.
Australian
Report this Post10-06-2017 05:19 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did the same many years ago.
