  1987 FIERO GT ACCENT PAINT COLOR
1987 FIERO GT ACCENT PAINT COLOR by txtallman
Started on: 09-04-2017 02:34 PM
Replies: 2 (261 views)
Last post by: txtallman on 09-07-2017 04:28 PM
txtallman
Report this Post09-04-2017 02:34 PM Click Here to See the Profile for txtallmanSend a Private Message to txtallmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I AM DOING SOME SMALL TOUCH UP PAINTING ON MY 87 GT. I KNOW THE CODE IS "WA9077" AND THE ACCENT SILVER COLOR IS 18L . THE CROSS IS WA7719 . I CANNOT FIND A DUPLICOLOR NUMBER FOR THE 18L ACCENT.
DOES ANYONE HAPPEN TO KNOW WHICH "DUPLICOLOR" MATCHES THE 18L ?????
paulmckibben
Total ratings: 57
Report this Post09-06-2017 03:29 PM Click Here to See the Profile for paulmckibbenClick Here to visit paulmckibben's HomePageSend a Private Message to paulmckibbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
The "L" in "18L" means that GM paint color code 18 was used on the lower portion of your car, the ground effects. From paintscratch.com you will find that GM paint code 18 is the same as WA7719, Medium Gray Metallic. You can order the matching paint from paintscratch.com.
Based on a search of duplicolor.com, it appears they no longer make the paint you need.
More info at http://fierosails.com/Paint.html
Paul McKibben
fierosails.com
[This message has been edited by paulmckibben (edited 09-06-2017).]
txtallman
Report this Post09-07-2017 04:28 PM Click Here to See the Profile for txtallmanSend a Private Message to txtallmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
THANK YOU , i AGREE WITH YOUR INFO, WAS HOPING MAYBE SOMEONE FOUND A SUITABLE SUBSTITUTE BEFORE I GO AND GET A CUSTOM COLOR MADE . JUST TRYING TO SAVE A LITTLE $$$.
