I'm about to start an engine swap but with photobucket done I thought I'd test how to embed photos with amazon. Good thing is, I found an LS4 locally so I can pick up some missing parts this weekend. I'll start a build thread after I've done some test fitting. i hope to drop the engine from my spare formula this weekend.
It lets you see photobucket pics just like you used to. Pretty simple to run, I had to clear my cache to get it to work but it works. You can google photobucket fix and get a couple of different ones.. this is just the one I used. Then you can do a build log like you used to.
Works but clunky. You have to click on a link and get redirected to another page to see each picture?
That wasn't the case for about an hour. It actually worked with the embed img tags. I posted the link with and without the IMG tags.
Originally posted by Danyel:
Not seeing the pics ..... why not use PIP ?
That's most likely what I'll do. But I want to be able to load from my phone. I don't think PIP works on an iPhone. Plus if I were to link to other forums I'd still need a hosting site. Ideally, I'd like to document this build in word with all the links and then copy/paste to the forums.
Originally posted by Easy8:
Went back and looked at chorme.. that one is failed but this one seems to be working fine.
Like I said, photobucket will chase the money and try to stop these.
