  Plastic fuel tank
Plastic fuel tank by timenewton
Started on: 07-04-2017 12:35 PM
Replies: 6 (1049 views)
Last post by: theogre on 07-04-2017 09:45 PM
timenewton
Report this Post07-04-2017 12:35 PM Click Here to See the Profile for timenewtonSend a Private Message to timenewtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what I have been trying to figure out is what are the measurements of the fiero fuel tank for 87-88. I think I may have found a premade poly fuel tank that fits but im not sure on direct dimensions. Also would a poly be lighter than the stock fuel tank? 5lbs is 5lbs you know.
Neils88
Total ratings: 56
Report this Post07-04-2017 03:32 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be concerned about whether or not the poly tank would be structurally as strong as the oem tank. What about grounding issues? Have you checked with DOT?
timenewton
Report this Post07-04-2017 03:37 PM Click Here to See the Profile for timenewtonSend a Private Message to timenewtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I mean they must have been making poly gas tanks for sometime now and this is the 21st century so I would hope that they are structurally sound. I mean look at all the choices for poly gas tanks http://www.gastankdepot.com/plastic-gas-tanks.html as for grounding I assume just ground to the car like everything else.
Tony Kania
Total ratings: 305
Report this Post07-04-2017 05:29 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Manufacturers have many variations of materials used for current model vehicle gas tanks. Some form of a polymer plastic is used in many of the tanks.
The Fiero has a very specific tank shape. It allows for the maximum amount of fuel to be stored within the dimensions available. I have no doubt about there being alternatives to an OG tank, but I would initially assume that other available tanks that fit within the dimensions available are slim.
Interesting thread and thought none the less. I would be curious as to where you go with this...
pmbrunelle
Total ratings: 62
Report this Post07-04-2017 06:49 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point... the real question is, is the new tank as big as the factory tank?
Supposing we're talking about polyethylene, it can be cut and welded (using polyethylene filler rod). So a slightly larger tank of approximately the correct dimensions could be made to fit like a glove.
I suspect that plastic fuel tanks are fluorinated; the tank is probably filled with fluorine gas (chlorine might work too) while it is still in the blow molding machine. This halogenates the plastic molecules, making them less porous, or more gas-tight.
I have a crappy plastic jerry can that always smells of gasoline, even when the cap is on. No actual dripping though. I suspect that it wasn't fluorinated.
At the places where you cut and weld, you would lose the fluorination treatment. For a project car, I don't think this would be an issue, but if you were trying to test a car for evaporative emissions, that might be different...
timenewton
Report this Post07-04-2017 08:50 PM Click Here to See the Profile for timenewtonSend a Private Message to timenewtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im just assuming that a poly gas tank would be lighter. The question is what are the dimensions and weight of the current tank, I need to know these before I can begin my search. I currently dont have my tank off because my car is running ha so if anyone has this info would be good.
Report this Post07-04-2017 09:45 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many Aftermarket plastic tanks are likely test to meet FMVSS fuel tank rules and marked DOT etc on the labels.
Ground thru the "bulkhead" where FP and Gauge sender are installed. Likely Second ground at fill inlet to ground the nozzle to car.
Plus 87-88 tanks have expansion tank under right rear 1/4.
You could try installing a plastic tank in that space but very likely will hold < OE tanks.
